Hi all,
This morning, I managed to damage my large garage door on my Autotrail Cheyenne 696 se (2004). Its not the Thetford door, its the large door.
In my infinite wisdom, I decided to take the door off. Taking the door off led to stripping the outer Aluminium frame off which led to completely dismantling the door.
It's made up of:
Aluminium frame
A core of composite / sandwich / foam panel (one side is Aluminium the other is thin plastic, the core is foam.
The door was knackered and had been bodge repaired before I got it. There was plenty of silicon in there and the foam had broken and this was causing the door to leak. I had planned to 're skin' it at some point but I got a bit too keen.
Has anyone done this job before and could point me in the right direction?
I have two sheets of thin Aluminium (pre painted White) which will do well for the outer skins but I'm stuck as to what to do about the foam? There were a couple of plugs in the Aluminium frame which has led me to think it may have been constructed using expanding foam?
We leave to go to Cornwall on Saturday!
Any help would really be appreciated especially from anyone that's done this job before.
TiA
It's made up of:
Aluminium frame
TiA
