fuses (1 Viewer)
Feb 15, 2014
711
1,246
cambridgeshire
Bessacar E450
3 years
citroen relay 2007 , are there fuses for the headlights? my drivers side low and high beam have stopped working,sidelight is ok though which I believe is through the canbus system. if there are fuses could someone tell me where to find them.
thanks
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Fuse box in engine compartment F14 right main beam F15 left main beam
Fuse box near driver dashboard F12 right dipped beam F13 left dipped beam and headlamp aiming device
ALL 7.5 amp each
movan
21,492
120,753
Moving around
Burstner
since07
Crumbs. Is there a way of knowing it is fuses when something goes wrong, please? I would have paid out for new bulbs ... and wasted my money again... :(
chatteris
Feb 15, 2014
711
1,246
cambridgeshire
Bessacar E450
3 years
thanks will look in morning, both bulbs were tested with multimeter
chatteris
Feb 15, 2014
711
1,246
cambridgeshire
Bessacar E450
3 years
fuses were ok, bad connection on dip bulb and main,all working but aim adjuster is running all the time lights on so not quite sure whats going on so I am going to put a new headlight assembly in as I have had a few problems and it has a bit of corrosion where it had got water in it.hope that sorts it
Reactions: Jim
43,295
49,268
If you mean headlamp auto-levelling system is working constantly there will be position sensors somewhere on the front and rear suspension arms.
The system senses the vehicle isnt level (via a preset reference point) by calculating the difference in the two sensor readings and adjusting accordingly.
If you can find the sensors simply disconnect one......the self levelling wont work but it will confirm if the sensors are bad or not.
Techno
Jul 28, 2010
15,475
20,756
May 2010
No John we don't have auto levelling on X250 headlamps
BTW headlights (new) can be found on ebay around £60 if you look
chatteris
Feb 15, 2014
711
1,246
cambridgeshire
Bessacar E450
3 years
the plastic block on the dip bulb connecter look like it had been hot so took the the contacts out of block and put on bulb and it worked then, high beam bulb was a bit intermittent so new bulb put in and all working, can only assume adjuster motor running all the time made bulb connecter hot,presumably it takes its power from the bulb or I have a short
