wanderer
A fellow camper is having a problem with his fridge it looks like the 3 amp fuse has blown , can you replace with a 5 amp fuse as I can’t find another 3 amp or is it no no
Check the supply voltage on site as if much below the 240v it will push the fridge amperage up.
No it won't, if the voltage falls, the amperage (and wattage) falls with it...
What your thinking about is - To maintain the same power consumption (wattage) with less voltage the amps must rise.
Just saying![]()
Always happy to learn and that was what I was thinking. Not being a electrical guy but I thought the wattage stays the same?
Not working on gas plus no power to the cooker igniscion .
So why is an American 110v hookup system rated at 50amps if 230v 16amp is more than sufficient.No the only constant is the elements resistance. Let's say for example it's 150 ohms.
To work out the current flow(I) for any given voltage i=v/r
So at 240v current = 1.6 amps
And at 230v current = 1.53 amps
So at 240v power = 384 watts
And at 230v power = 351.9 watts
Sounds like your possibly on site at the moment? If that's the case I would consider 2 options:Not working on gas plus no power to the cooker igniscion .
3 amp fuse seems a bit low, might be worth checking in the wiring diag and manual if this is right, does it work on gas or is it just the 240v side that has failed?
A Use the outdoor fridge if in the uk and drink the beers & look at it in the morning.
B If your in a warmer climate pop the 5A & hope its not going to do further damage or make some space in yours and go back to option A.
OK, that's fine you can believe what you want.Like MikeD I believe watts are a constant... A unit of power produced
A 55watt headlamp bulb require the same amount of energy at 11v or 14v.... So the amps vary.
If the amps and volts were reduced the brightness of the bulb would also be reduced.
But a 55w bulb is only 55w at its rated voltage. The amps reduce if the volts reduce.
Voltage can be defined as pressure between two points, as the pressure decreases it pushes less electrons (ie less current). Get it?![]()
your theory
Actually you are both right. It depends on what type of device it is.No it won't, if the voltage falls, the amperage (and wattage) falls with it...
110V 50A is equivalent to 230V 24A. The round blue plugs come in two ratings, 16A and 32A. The 32A version is slightly bigger and has the polarising notch at the top instead of the bottom. 32A hookups are rare on camp sites but are available at some marinas for the larger boats.So why is an American 110v hookup system rated at 50amps if 230v 16amp is more than sufficient.
