Hi Thanks for the replay, Yes that is the one for the fan and car sterio it says , but it is not for tha main one,i Can not find it,i have been in the engine room as well and the fuse box there is from hell, iv checked all of them there as well,but no luck, i will try to open up the dashboard tomorrow to see if i can see where its going... strange, ,thanks
thanks , for the replay, i will look into it tomorrow, under the passenger seat there was some fuses ,but,no .in the Ebl there was one fuse for radio ,but no,wil check the fuse box in the engine tomorrow.
We had an electric window fuse go on our MLI 580, which I appreciate is a different beast.
but the fuses for the windows and others were located under the drivers seat, on the right hand side. So there might be another set of fuses there? Big problem is of course access as being a class with no door the gap between the right hand side of the seat base and side of MH is very tight.
HI, awaiting answer from hymer,but have now checked under the seats, and some fuses but no... i can follow the wire under the glove box , but can not find it on the side, wil check again later wit somone shaking the cable ,but i do not want to take apart more, i will take the power from some where else if i can not get an answer from hymer! no space there at all...
