Can any one tell me or recommend a company to fit air suspension in Scotland or North England.
Depends on what the OP wants to achieve but, if stable levelling is important, a good idea to get it all done together.Do yourself a favor and fit the e&p hydraulic jacks too well worth the extra
You can fit airbags inside the coils , this would give you a normal ride when not heavy and inflate to assist with heavy load , if you fit HD coils you will get a rougher ride when not loaded up .
VB Full Air 2C with Emergency inflation valves ,Front coils as you cant fit air to the Mercedes Sprinter ,E&P leveling system.
If you are referring to the 2016 sprinter i do not think you can fit air to the front with the VB system or so i have been told by VB dealers.
We have pretty much the same as this already fitted, as you say there is no option for full air on the Sprinter, what are you having done at your front end? new coils?
Does he 2016 have McPherson strut type front suspension ?
Yes new coils to be fitted
This is what concerned us about full air, being stranded if a fault developed. The coils, torsion bars or leaf springs are removed and the vehicle is only held up by the air bags. No doubt this is a rare occurrence and the systems are designed to be near bullet proof but it still put us off.Just out of interest...
If the compressor goes defective on VB full air suspension, does that render the vehicle unusable, or can the air bags be inflated and held at pressure manually?
