Fuel Range (1 Viewer)
Jun 18, 2013
259
7,725
Essex, UK
Rapido 666F
Since 2015
The other day, I learned a lesson about the onboard computer.
We have a 2016 Rapido, Fiat chassis, standard cab, tank, etc. Driving from France to Spain, I wasn't in any hurry to fill the tank at French motorway prices for diesel but still had about 80 miles in the tank as we entered San Sebastián to camp at Camping Igueldo. If you don't know the approach to that site, it is up a 4km long hill, very steep at the start and narrow all the way. About a third of the way up, there is a loud beeping, accompanied by a low fuel warning and the range went to nothing, well three dashes. No real choice but to carry on and of course we made it.
Checked in at the site but decided to return to the town for fuel before parking. By the time we got to the bottom of the hill again, the range was 180 miles!
In the UK I had run the tank down to a range of 20 or 30 miles, just to check it out. All had been well and I'd built some confidence that it was reasonably accurate, but that was on the flat.
The fuel gauge itself was showing just on the upper edge of the red marks throughout the up and down journey, so logic told me we would be fine, but it didn't half concentrate the mind and exercise the buttock muscles when the alarm went off!
Lesson learned that we would be better entering hilly areas with at least half a tank.
Oct 29, 2008
5,058
5,911
West Yorkshire
PVC
since 2008
If I drove my van like a grandad I can get over 800 miles, On a level and cownhill route Ive seen up to 1200miles range on the display if driving at 50ish
Jan 22, 2012
1,459
2,229
Wigan
Knaus Sun TI 2012
I had a Volvo car once and even if you had about 2 gallons in the tank when going up hill the warning light would come on. We were once pulling a caravan through a remote part of France and it just cut out on a hill. We were stranded and about 5 miles from a campsite and garage. Some lovely French people came to our rescue. Happened again on a hill in Croatia. On both occasions there was plenty of fuel left to get me to the garage, it was if all of the remaining fuel went to the back on the tank on the hill and away from any feeder pipe.
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
My antique MH does not have a fancy gizmo to tell me how far I might be able to travel on the fuel in the tank. I have never had a car with a reliable fuel guage, always having travelled twice as far on the first half tankful as on the second.
The simple solution is nearly always the best solution, reset the trip meter to zero when filling up, by experience learn how far you can travel on a tankful and act accordingly. We can cover about 600 kms so I start thinking about fill up after 300 (living in rural France makes you think like this) particularly as we tend to avoid motorways.
Remember, PPPPPP.
2657
Any manufacturer with any common sense would locate the feed from the tank at the rear, strangely vehicles will coast downhill...........can't think why:)
43,301
49,289
Doesnt matter where they put it, the internal dip tube will be very near the lowest point of the tank....and often in the center.
Chris
21,044
277,976
None
10 years
In my first car ( a mini) the fuel gauge didn’t work so I carried a stick in the boot to measure the depth of the fuel still in the tank(y)
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
The last thing you want is an unnecessary alarm going off. In Fiat, they all seem the same, so you’re forced to turn attention to the precise nature of the ‘call’. I had that happen on a busy, narrow and unfamiliar ascent (25%) a couple of years ago and it was most distracting.
2657
Would that not be the 'feed' then, lowest point of tank at rear would seem logical to me but I do realise there are often design constraints.
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
The readout will vary depending on your average fuel draw for the previous few minutes ish. So if a long uphill it will take that as an average and vice versa and show range accordingly as if you were at the same speed and rpm at that moment.
Sep 1, 2017
222
85
What Dave said. When you take the Valencia to Teruel road the range shrinks as you climb towards 1200m of altitude.
And coming the other way, it rises to mimic my plug in Prius.
Aug 18, 2014
23,742
133,205
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Why would you even want to run it that low & apart from putting yourself through agonies over how far to the next fuel station there's always the likelihood of dragging the rubbish that might be in the dregs up into the filter.
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
Payload.
If it's tight, only put enough in for the journey, plus a margin.
When you go up a steep hill with 1/4 tank, the reserve light may come on, followed by the "out of fuel" alarm as it gets even steeper. The range calculation becomes meaningless as it thinks there's much less fuel than there is at a time when your fuel consumption is also abnormally high. Sadly, the range forecast is wildly optimistic on the return journey but we can always dream.
Lenny HB
53,309
149,502
On the coast in West Sussex
Hymer B678 DL
All 3 Ducato based vans we have had the range blanks out at 35 miles to go, drive another 10-20 miles and when you fill up always over a couple of gallons still in the tank but you still panic. Wish I'd ordered the 120 Lt tank.
Oct 2, 2008
4,466
7,940
Salopia
Duro 6x6 Overlander
since 1968
Be careful what you wish for , it nice having a big tank (378L) when you are driving , not so nice when you have to fill it again :(
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
Get a Jerry can.
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Never let mine go under 1/4 .
Nor me.........time to fill up methinks.....
