Fuel filter change (1 Viewer)
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Thinking of changing the fuel filter on my 2013 Fiat ducato 2.3
Done a few twist of one's in the past.
Do you just press the clips on the fuel pipes to release?
When refitting are they just a push fit till it clicks .
Then ignition on to pump fuel up.
I noticed that there is bleeding screw on top does this have to be open to get all the air out?
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
A photo of filter
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
I was about to say is it plastic or metal but the picture tells all. mine is the plastic type but if the connections are the same it is just a matter of pulling the collar back and they should release. I'm sure a mechanic type person will be along shortly with more knowledge than me
Oct 29, 2012
887
1,045
essex
Rapido 9090df
and if you want a demo there is one on youtube
SandraL
1,373
985
Somerset
Hymer b694sl
Just press the coloured button in and pipe will pull off. Mine were different sizes so cannot be put on reversed. On base of filter mine had an electric sensor, hardest part was getting plug off !! Remove this plug before taking filter out. Carefull not to overtighten this sensorwhen put onto new filter.
On completion turn ignition on but do not start. You will hear electric pump in tank runnng. Do this for a couple of times, say 15 secs each time. Then start engine. No air bleed screws involved on our 2012/13 3 litre fiat.
laurieash
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
There is a bleed nipple on top of filter
