thinking of getting EFOY fuel cell anyone got one will be doing a lot of wilding any thoughts on them. Thanks
Nominal consumption / kWh 0.24 US gal / 0.9 l
W=VA so A=W/V so 1000/12.7 = 78.74 amps Methanol @£4.80 per litre = £4.32 so in conclusion a full charge (from 50%) on a 160 ah battery would cost just over £4.00.
Martin
Don't look too hard they might be wrong.WOW!! You lost me at W=VA having said that I’ve just enjoyed a Pint of San Miguel so I’ll look at the figures again tomorrow
I bought one second hand when bought my motorhome 3 years ago. Mine in the older 1200 one. I wild camp 95% of the time. My first summer with it I thought it was a waste of time as I never used it as I was covered by solar panels and never needed it. Then came the winter months and I realised the benefits of it. Now I would not be without it.
When it is on it gives out a slight humming noise. I actually find this soothing when I go to sleep. I use a NASA BM2 battery monitor to check my power usage and I turn on the EFOY when my batteries get to about 60% on the monitor. This is usually late in the evening. When I wake up my batteries are always showing 95 - 100% full ( 2 x 100 ah batteries) The EFOY tops up the batteries, it is not like a generator that can run a microwave, it is a top up charge over night. You can leave it on Auto if you wish, but it will top up during the day when solar can also top up.
Cost for running it so far are minimal. I buy 2 x 10 litres of methanol at a cost of about £90 and this last me for about 18 months. But I never have to worry about running out of power.
When ever I get a new MH I will be taking this with me.
End of the day though if you are wild camping and two average batteries are about flat you could get then back to charged for around a fiver.
Martin
You are right it can have a place and should be managed sensibly, it doesn't replace solar which to me is the best addition ever.I’ve been considering having an EFOY system for a while now and from what I can tell, managed correctly the running cost need not be prohibitive and the confidence in knowing you are always going to have Batteries operating at a reliable charge level is really reassuring.
I am definitely going to get the system fitted when I return to the UK in the Spring.
Any recommendations on a supplier appreciated.
EFOY is easy to fit if you are remotely DIY, it comes with very good instructions and is only a couple of wires, a small hole through the floor for the silicone exhaust drain tube as the only bye product of the combustion is a little water and heat, the water goes outside the heat can stay inside as long as the space it is fitted in is not too enclosed, the control panel is on its own plug and the fuel pickup just screws straight onto the top of the container.
I get my fuel from Fuel Cell Systems but bought the unit from a place at Pocklington near York thinking I would be able to pick it up but he ordered it straight from his supplier and got it delivered to us.
Martin
Thanks for the info, I never realized the simplicity of the installation and I’ve now downloaded the installation guide. The Efoy will be sited within a 500mm of the Battery Compartment in the rear Garage with the exhaust going through the floor.
I have 340 watts of Solar,3x170 Batteries and a Votronic 430 MPPT Controller, I believe the EFoy140 will be suitable.
We do spend quite some time without EHU on a recent jaunt we went 6 weeks without a problem but in the main the Sun was out most days,however,we have at times moved on because of the need to top up and this is were the Efoy system will take away our concerns and interruptions.
Yes, thankfully the Compartment and space to site it is at the Tail end and the exhaust is as you say the water tube.EFOY 140 should be fine, don't site it too close to your head end of your bed as when its quiet you can just hear the pump. When you say exhaust through the floor I guess you mean the little tube for the water, the off heat tube should be fine in the garage and the cooling works OK as it usually a cool day when you need the EFOY.
Martin
