Fuel and Standing for months... (1 Viewer)
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Put the M-home on a SORN a few months ago...
And won`t be taxing it for another month or so... when I parked up there was just over a quarter of a tank of fuel, been started a few times and moved around and battery kept topped up (Put on Charge)..
Normally when parking up I make sure the fuel tank is full.... now...
Should I drain all the fuel (Couple of gallons at most) and dump and refill in case of condensation from standing... or ..
Just top up and let the water filter take away any condensation if there is a water filter or what ever they are called.. or is there NOT likely to be any water (Condensation) in the tank..?
Thanks.. (y)
Mikey RV
4,901
24,233
Devon
Burstner Elegance I821G
Since 1977
I would not worry about it. Think about all them motorhomes parked on forecourts at dealers with just a bit of fuel in, then someone buys it and off to the nearest garage to fill up. (y)
Apr 21, 2009
546
34,990
East Cowes, PO32 6RU
Caravan
Caravan since 1970, motorhome or RV since 1999 then back to a caravan in 2017.
I have read on USA sites about diesel going off but have not experienced, no heard, of any major problems in UK. I would therefore echo @Mikey RV and @simsy56 and just fill up ready for your travels.
poacher
114
242
Mo,
Know “times are hard” ‘cos you are making your CL large enough for ‘us’ big boys :whistle:
but,
I would dig deep and put a dose,or two, of diesel biocide in the tank before you fill up
(Bottle of Wynn’s is about a tenner and is lots of doses)
Will take care of any diesel gremlins that might have sneaked in when you weren’t looking
poacher
May 7, 2016
7,251
11,733
West Sussex
Carthago Compactline
Since 2003
From my boating days I recall that the problem was not the water itself but that the diesel bug could bloom if there was water present. Hence the advice to keep tanks full to minimise condensation. One boat I bought had a serious invasion of the bug in both tanks and it was one hell of a job to get rid of it. However I think it had been unused for a lot longer than a few months. I believe there are biocides available if you think there is water in the fuel but I would hope that modern road fuels are not infected in the first place.
Does anyone know whether modern diesel fuel comes pre treated?
DuxDeluxe
14,658
72,764
Planet Zog
A woosh bang van
since 2008
There is no biocide present in normal EN590 fuel. Once you have the dreaded aerobic bacteria it is a sod to remove and might take a few biocide treatments. Having said that, you are pretty unlucky if you get it.
Keeping the diesel tanks full to minimise condensation is a very good idea
Aug 27, 2014
1,910
3,928
Shropshire
McLouis Tandy 640+
Since 2014
I'd keep diesel tanks full for all the reasons mentioned above. Diesel doesn't seem to go off - unlike petrol, which is more of a pain, the modern stuff does seem to go off - says the man who has some motorbike carbs to take off and get ultrasonically cleaned due to blocked pilot jets due to standing with petrol in :cry: The petrol evaporates and leaves a varnish like residue that is a nightmare to remove, ultrasonic cleaning seems to the only thorough way to do it. Funny how my old lawnmower never has any problems though after standing all winter, but I guess it is a very crude carb and engine so maybe a bit more tolerant.
Even adding fuel stabiliser doesn't seem to keep petrol fresh for too long any more.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Add two-stroke oil to your last tank of petrol at, say, 50:1. You will not get varnish when the carb (or injection system) dries out.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Not knowing what your `van is, nor actually how long it has been standing. All I can tell you is that when I was living in mine, for up to a year whilst doing a bungalow gut out and refurbishment, I had a part full tank of diesel, for most of that time. She Fired up OK first time and the "water in fuel light" stayed off. After which we went off to Spain for 3 months. I was forced to leave the Winnebago in storage one year for nearly 9 months, due to SWMBO`s medical issues, with a tank full of Unleaded, with just some "generic fuel treatment" in it. right through a Texan winter. Again no issue when I started it up, and we took it all the way to Wyoming that year.
filopastry
1,016
1,738
london
littleun
newbie and learning every day
With petrol there is a marked octane drop over time and the risk of bacteria much more so with the modern lead free. In microlighting we never hold fuel in the tank for extended periods even with two stroke oil in. If it is in the tank more than one month, I will drain it out and use it in the garden machine, but then it is a little more important in the air.
PETROL.
DEISEL.
Oct 27, 2017
1,409
3,157
Perth
Hymer A Class
Since 2014
Jetlag, you don't fly enough. Fly it every week, if possible. Better for you and the plane...
