The Fridge on our van, a 2010 Burstner Solano has worked properly for the 15 months we have had it until now..
I had to uncouple the gas bottles in the locker and then re- connect them. Bled the gas through the hob no problems, so cooker and heater work fine on gas .
Fridge works on 12v and 230v no problem. When I switch it over to gas (or having AES, it selects gas) the display alternates between "AES" and "GAS" as it should and the blue "on" light displays for about two minutes then flashes red and simultaneously the red "failure" triangle flashes and a "beep" alarm sounds. I should say at this point that I cannot hear any clicking as though trying to ignite.
The manual gives the advice below....
There IS gas in the bottles.
The Shut off device is open
There is gas in the pipes at the back of the fridge at least up to this elbow...
I have 'switched the appliance off and started again' until my finger is worn to a stump but still cannot get it to work on gas.
I searched the internet for answers and found on another forum that it is possible to reset an appliance with a similar Dometic number after gas disconnection by pressing the red flashing triangle for a couple of seconds but there is nothing to press on mine..
I have filled in an online enquiry for with Dometic but it was rejected as it did not support the "Article No" that I supplied!!
There is electrical power to the appliance so can I rule out a blown fuse?
Anyone any suggestion before I call out an engineer?
This is the spec of the appliance..
I am reluctant to try and get to the burner to blow it clean as it is not very easy access and I can't see what I am doing other than with a reverse image in a mirror which makes my head hurt
