Front Remis Concertina Blinds Bonding Together (1 Viewer)
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
I recently posted this on an owner's forum, but not yet found anyone with a similar experience and thought I'd try a bigger audience.
When the van's not in use at home, I keep all of the blinds closed, to prevent prying eyes and also to keep the heat and light to a minimum. On several occasions now, when I have gone to open the windscreen blinds, I have found that they have bonded together, I'm assuming with the heat and I've had to use considerable force to prise them apart. The force is enough to make me think I'm not far off breaking them.
There are magnetic strips held within aluminium extrusions, which form the joining face of each blind. When the blinds are closed, the magnets touch together and keep the blinds closed. In my previous two vans, the magnets have barely been adequate and I've resorted to using elastic bands to help keep the blinds closed.
This issue is not 'over strong' magnets, as they easily release if I open them shortly after closing them. It is only after a few days of heat and it's as if the faces of the extrusion are melting and fusing together. Once forced open, there is nothing on the faces to suggest they have been stuck together.
When trying to open them a few days ago, the force caused the handles to fall off ! I've got a short video of that, but it won't load due to being too large ??
I have managed to fix the handles back on and coated the faces of the magnets and extrusion, with French chalk dust, hoping this would solve the problem, but they were still firmly joined together today.
A tape on each face, or a thin coat of Vaseline are my next options.
Dec 23, 2015
444
522
Audenshaw
Pilote Pacific P650GJ
Over 6000 miles between 3 March to 26 September 2017.
We have the same problem with ours. Can only imagine that the longer you leave them closed, the stronger the magnetic force is. The first time it happened I had to separate them with a table knife! It is rather worrying as we have to use a lot of "brute strength". As you say, once they are opened, they are fine until left for a week or more.
Feb 22, 2011
9,785
20,150
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Maybe a bit of adhesive used to stick the magnetic strips to the aluminium frame.
I`d try the chalk dust or vaseline, I`m sure that will cure the problem
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Same happens to us, nightmare to get undone and like yourself the Handle has come off, I found by holding both clips and gentley pull apart at a slight angle (tilt) rather than pulling apart seems to work better if that makes sense
Must have changed the design somehow, our previous van x250 worked much better and it looks like they have also changed the pleated material on newer versions
Feb 24, 2013
13,079
101,443
Bolsover, Derbyshire
Hymer S800
not long enough
and I thought my broken clip was a problem o_O
can you pull them nearly closed when left, so not quite attached to each other (y) the gap will not let much heat / cold in / out and not much visibility for badduns, not what should be needed, but may stop it being an issue.
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
@DavidG58 That would work, but the tension in the blinds pulls them open to well over half of the screen, so they wouldn't sit in a 'nearly, but not quite' closed position, without devising something to keep them nearly closed.
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
I'm not convinced that the magnetic force of what are basically two fairly weak magnetic strips, could increase to such an extent where knives have to be used to lever them apart. Magnets tend to lose their strength over time, rather than increase it.
Certainly on mine, it feels as if something could be leeching from the contact surfaces and bonding them together.
cornish boy
892
2,365
Body in Hampshire, heart in Cornwall
Swift Kon Tiki 669.
not so newbie anymore - since 2016
How about running a strip of sellotape down both edges so when they are closed the two surfaces can't touch but the magnets can do their job? (y)
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
Great minds think alike :D
The only reason it wasn't ahead of my French chalk attempt, is that longer term, I imagine the heat affecting the tape and ending up with a sticky mess of partly stuck sellotape.
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
I didn't think they were meant to be used for prolonged periods of time. Think I read that somewhere.
If we are parked up for several days we use our silver screens, only draw the Remis blinds at night.
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
I don't know, but will have a look through the bumph to see if it carries a warning - thanks.
I've read similar about the older types of side window blinds, where prolonged use would cause them to lose tension, but can't see why this type of Remis would suffer from longer periods of being closed (other than the point of my post of course ;))
My previous vans had the Remis fitted and were fine over long periods.
cornish boy
892
2,365
Swift Kon Tiki 669.
I must read posts more carefully
howabout using cling film to test out the theory?
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
I need some sunshine to test any theories, they only stick when it's hot. Perhaps now that summer is over, the problem is solved for this year :rofl:
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
We are currently away in France and experiencing high temperatures (sorry:D), and have experienced this issue but I remember reading a thread on the exact same problem last year. Someone had advised to pinch the two handles together before opening, I can confirm this method has worked successfully. In the name of research, I will put this to the test again as we are expecting temperatures to reach 30c (sorry again to those currently in Blighty......:whistle:)
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Don't have this problem as I never close the front blinds - the concertina design is so flawed they take about 3 weeks to fold back into the pillars!
Have resorted to hanging a sheet up tucked into the overcab bed !
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
You can quickly go off some people ;):D
Dec 23, 2015
444
522
Audenshaw
I'll watch this thread with interest to see if anyone comes up with a foolproof solution. We're going up to the moho today, it's been shut up for a week and we've had no sunshine, just torrential rain and wind. Just for the record, one of our handles came of but they just clip back in.
Stretto Boy
1,503
306,439
Leicestershire
Since 2011
I suppose you could use silver screens for longer periods but I accept that's not really the point when you buy a van with Remis screens fitted. I haven't experienced this problem myself but then I haven't had them closed for longer than about 48 hours and so outside the parameters of what you are experiencing. Good luck with finding a solution.
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
.......We're going up to the moho today, it's been shut up for a week and we've had no sunshine, just torrential rain and wind....
Let us know how that goes please.
Mine have been closed since bringing the van back from my dealers on Thursday and I need to go out to it later to get my bag of handbooks, so I'll give them a try.
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
Same with mine, but I've read somewhere that remis know about the problem and if you complain they send some tape out to put down the edges and this cures the problem.
John.
Louis
1,204
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
John.
Stick on draught proofing sponge on one edge ? :)
Welsh girl
3,658
3,036
Globecar
Since 2004
What about a strip of polystyrene that you get in some packages. Place that in between the 2 blinds along the edges and the use a short bungee to keep the handles together.
Nov 4, 2015
139
1,007
Waterlooville
PVC
Since 2011
I've had the same problem. Have always managed to overcome by squeezing the two handles together so that the end strips rock towards each other and then part. Using force to pull apart is likely to damage the blinds.
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
We tend to use the silver screen more ,never had a problem with our blinds ,but we have had problems with our dash melting or going soft when it is hot and always seems to have sticky feel.Not sure anyone has had the same problem it just seems to be to a max 100mm from the screen the rest is ok .We have started to lay a silver screen strip over this area and it does help when we remember lol any advice would be appreciated. Lol
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
I really must start reading instruction manuals :whistle:.... Thanks for the pointer and you are correct, the owner's manual states....
"The system is not intended for use as a blind over longer periods of time (e.g. storage over winter)"
Obviously that could be for several months at a time, whereas this sticking issue is coming up after only a day or two of heat.
The only other warning in the manual states "under exposure to intensive levels of solar heat, the handles may remain hot for longer periods of time". Mine hasn't reached high enough temperatures to make my handles hot yet and there's nothing in the manual about the possibility of them sticking together.
cornish boy
892
2,365
Swift Kon Tiki 669.
We leave our blinds across whenever the van isn't in use or we are on a site. In fact they are pretty much always normally closed except for when we are driving and never had any issues with them sticking.
Now I have said that, I expect that when I go out to it in a minute I will find them stuck. :)
Kingham
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
John.
In my most fluent schoolboy German, I've just filled in an online contact form with REMImobil.
If they understand gobbledygook, I might receive instructions on fixing the problem, or a roll of tape, which I expect will be hi-tec, specially developed heat resistant stuff and not an end bit from a roll of Sellotape's best :D
The blinds opened correctly when I tried them earlier.
Dec 23, 2015
444
522
Audenshaw
Just back from ours and, yes, they were stuck. We didn't struggle with them as we were only calling in to pick up an empty Calor bottle for exchange, but that's another story :(
