Fridge
Mar 31, 2015
250
263
WORCESTER
Autotrail 660 merc
SINCE 2012
after spending tow very windy nights on Xmas eve and Christmas Day rocking from side to side in north wales ( no it wasn’t the sprouts).
Fridge now keeps going on and off ,on gas it’s ok four half hour then keeps clicking on and off. Changed gas bottle any ideas please.
Autotrail motorhome.
Andy
LOOSE WHEEL
Mar 31, 2015
250
263
WORCESTER
Autotrail 660 merc
SINCE 2012
Is that just take burner out and give it a clean Mo.
Andy
old-mo
Extra Special
15,977
79,866
Weymouth. Dorset...
PVC.
Caravan & motorhome 45 + yrs
Andy
Give it all a good blow out... sounds like a bit of soot is partially blocking the jet...
If you have been running on gas at some point and not been exactly level you get a soot ball develop in the chimney which when dislodged can drop down partially blocking the jet..
Got to be worth a try... (y)
LOOSE WHEEL
Mar 31, 2015
250
263
WORCESTER
Autotrail 660 merc
SINCE 2012
Will do, off today but at moment it’s raining cats and dogs here in Worcester, thanks for help.
Andy
Jul 12, 2013
3,067
3,606
The City of Henlow
Adria Supreme
Since 1980
I had a lovely Dometic man look into my jet. He took off the jet unit and using a Co2 can, gave it a good blow.. I actually saw bits of muck fly off. Job done!
Personally I would have been less confident than him, in removing the jet which he did in seconds.
It could of course be many other things causing your problem. Check the colour of the flame which I believe should be blue. If not then you are checking out the right area.
LOOSE WHEEL
Mar 31, 2015
250
263
WORCESTER
Autotrail 660 merc
SINCE 2012
Took it apart and you could see that the flame was all over the place.
Took screw that you can see in pic out dropped burner down and give it a good blow out with air line. Seems fine now but time will tell I,v also checked all those wires that dpsuk999 said about just in case.
Well that’s this years subs payed for just in knowledge alone many thanks to everyone.
Andy:cartoon:
