Fridge works on gas but not very well (1 Viewer)
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Been a bit of a head scratcher this one over the last few weeks.....
About 6wks back the fridge seemed to fail on gas when we were away, no big deal as we were almost on our way back. Following week i brought the van to the house and switched the fridge on and left it overnight. Next morning the fridge was cold, hey presto it was fixed(n) or was it...
Next trip, fridge seemed to work but not well. Tried again at home got even more confused, since decided to add a permanent fridge thermometer (not arrived yet) and this in the midst of the heatwave i started to think it was simply the fridges inability to cool given the +35º outside.
Ok have been in wonderfully warm Blighty for the last 12 days and it can't cope with that either... tested it on leccy and it's fine and gets super cold as usual but on gas it fires up like normal and burns gas as usual but it just doesn't seem to get that cold, the butter test says that at least...
Having ready many threads on here i wonder where i should start in my fault finding ?
It's a dometic fridge/freezer with auto switching, the classic type in many campers today. It's 5yrs old although has never been serviced ???
Any ideas ?
TerryL
6,184
8,181
North East
Low Profile
No expert but the fact that it works fine on electric but not on gas suggests that it could probably do with servicing. As a minimum the flue would probably benefit from brushing through and maybe the jet. BUT DON'T STICK ANYTHING INTO THE JET as you will damage it, just a brush and/or blow through with an airline.
Other thoughts; you have plenty of gas and all other gas appliances working correctly (so regulator is okay)? Are the external vents clear - no covers fitted for example - so that there is a good airflow?
Ours always cools better on gas than electric.
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Thanks Terry, yes plenty of gas (new bottles) and hob is running perfectly as normal, also no covers etc on the vents. Yes our fridge always seemed to run colder on gas vs electricity and it ran well on both.
Aug 4, 2013
1,140
140,158
Oop North
None now 😢
On a recent site in Italy we found we needed the shade of the awning to keep the fridge cool. It worked much better on gas with the awning out shading the vents.
Feb 21, 2016
4,918
29,522
Uk
Since 2017
Clean the flue/burner. Maybe a new jet?
TerryL
6,184
8,181
North East
Low Profile
Good idea - I often wind the awning out a little to shade the fridge/vents.
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
OK cleaned the flue as best i could yesterday (still on the road) but managed to get a radiator brush from a hardware store that did a pretty good job although i could only access the flue from the bottom as the top has a 90º T on it which can only be removed if you take the fridge out ! Anyway tons of soot came out and the fridge is running a lot better, after 24hrs the temp is now a measured 3.1º vs the 12-13º it was before the flue cleaning.....
also glad i have the thermometer in there, just quick glance tells you if things are OK or not, no more butter test !
Feb 9, 2008
8,946
18,702
Corby, Northants
Coach Built
The T on the top is usually held in place by a small screw and at some stage you will need to take it off to access the baffle inside which will be hanging on a wire bridge at the top of the tube. Both this and the tube will need a good clean.
TerryL
6,184
8,181
North East
Low Profile
There you go then, sorted but keep an eye on it for a few days in case it's the change of weather that makes it better. When you get the chance do as Phil says.
Thanks for keeping us updated.
19,342
30,216
The newer ones don't all have that T piece and baffle, which would make it much easier to clean.
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
Hi if you trace the pipe from the flame back to where it goes into a valve (not sure what they call it ) Give the valve a tap with a spanner as the valve inside can stick if not used for a while ,that may give your he presto moment .keeping your flue clean is also important lol.
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Yes will do that, just got back last night so it's a job for this WE. I reckon if i take the fridge out and then remove the screw i could leave it without the screw when i replace it as i'm pretty sure the T piece is going to be a tight friction fit. That would allow me to clean the flue fully in the future without having to remove the fridge.
Mar 23, 2012
9,545
32,079
sleights
c class
Ors (Thetfoed) was the same I swapped the burner for a new one seems to have sorted it. Didn't clean the flue as it looks like it will need to be a fridge out job anyone know any different. Its a lot better now but still not like it was before.
Feb 9, 2008
8,946
18,702
Corby, Northants
Coach Built
Correct! That's what I have done.
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Anyone know if the burner jet is easy to source, what price and easy enough to change ?
Think I might just get a spare to keep in, just in case...
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
This is a US RV video but the burner looks to be identical to the one on my Euro Ice cream van fridge/freezer
Feb 9, 2008
8,946
18,702
Corby, Northants
Coach Built
Leisure direct will be able to supply a complete burner assy and a new jet. Burner assy around 90-100 quid and jet about 18 quid depending on model of fridge.
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Cheers, will take a look.
PhilandMena: do you know what the baffle is for ? and is it easy to remove, you mentioned it's on a wire ?
19,342
30,216
The baffling is just hooked over the pipe once you get the T piece off the top.
19,342
30,216
My experience is that the jet itself is not the problem unless it is blocked with rust in the pipe behind the jet and then that cleans out OK, the airways on the burner assembly itself have caused me more problems when they become constricted and then the flame burns rich/smokey, I carry a can of compressed air to clean the burner head.
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
That's seems like a very good idea, used my tyre compressor last week but it was far to week in terms of power, so a can of compressed air would be good for that.
Feb 9, 2008
8,946
18,702
Corby, Northants
Coach Built
The baffle is a flat piece of metal twisted into a spiral and about 3-5 inches long. It's purpose is to disrupt/impact on the hot air going up the flue. If it has a secondary function I'm not aware of it. They become heavily covered in soot over time.
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Back to the same issue with my fridge, another "warm fridge weekend"
1) flue clean ? probably not but was done only 12 months back (will do it again though)
2) weather too hot ? actually was only around 22 - 28º and have recently fitted the CBE fan kit so i think that should be OK
3) Gas only issue: seems to be so as the previous WE it was fine on hook up, this WE on gas and we're back to a non working fridge
4) fridge was well chilled down: yes had it switched on mains for 24hrs before we set out and the temp was a lovely 4º
So my plan is
1) clean the flue (much easier now the top T piece is removable)
2) take a large hammer to the burner assembly and jet and then replace.....
Did i miss something ?
Ridgeway
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
PS: noticed before when i took some pics that the burner assembly is actually lower than it should be (approx 7-8mm) thanks to a missing grub screw (if i remember well the thread is stripped in the flue casing). Also wonder if that can cause an issue ?
Sep 3, 2012
7,552
26,059
Cheshire
C Class Elddis 175
8+ years
The burner head needs to be at the correct height to operate the fridge efficiently, ie evaporate the coolant. If you can't get a grub screw in, I would lift the assembly on a metal or ceramic block to the correct height.
If you can remove it OK, put in a bigger thread to take the next size grub screw.
It works OK on electrics so must be down to the gas burner not burning close enough to the evaporator. (y)
