You’ve already undone the locking screw on the left, now you pull it out from left side and it will click off the tang on the right (a little pressure on the frame edge inward does help the click, green dot)
Wayneliz. It's exactly as others have advised.theres a very small tounge on the right goes into a slots so as said left side out and a slight pull to the left if that screw was already out it may have been glued
Very true.but he carefully as the vents are made from "polycrackathene"
