Just a quick post to say that I have (at last) done the fan install...
I used a strip of 1 inch metal roof joist banding to attach the 2 PC fans to the lower lip of upper fridge vent grill opening. I then removed the lower vent grille and screwed a tupperware type small box to the L/H side of the opening wall. Took a feed and earth from the fridge loom and via an on off switch, attached the controller, then stowed it in the aforementioned box ( via a small access hole in the side of it ). That allows me to turn off the system when the van is parked up at home with the fridge turned off.
Plugged in the temperature sensing bulb and hung that from the "roof" of the top grille hole just above the
fridge fins.
Wired both PC fans through said small hole in box.
Switched it on... and Bingo, it all lit up...
The controller (which I can view through the transparent lid of the box), showed the current ambient temperature also the cut-in temp in one window and cut-out temp in the 3rd window..
I can adjust both cut in and out temp's later ( by removing the lid of the box ) when I fire up the fridge and test the system...
Next day, I was helping a mate, and I fell off the ladder. ! ! ! !
So... Nothing broke BUT, feeling very sore, as I fell on my ribcage, and the intercostal's are a "bit bruised."..
So will test the install when feeling less sorry for myself
Good luck with your installs, if you haven't already done them (Mel Et Al ......)
Mitch.
fridge fins.
Mitch.
