Can anyone explain the difference between obsorber and compressor fridges. Advantages and disadvantages. Thank you in advance
Not necessarily. Solar might compensate and, maybe, a second battery.
Some 12V compressor fridges are reasonably frugal.
The initial start-up requires more 'grunt', so I assume that models for use where there is limited battery capacity may have a deliberately extended cycle.
Unfortunately most PVC converters are fitting them so if that's what vehicle type you want your choice would be very limited. We have a Thetford T1090 mark 2 compressor fridge (the mark 1 version is cr@p IMV) and it does draw quite a bit of power, usually coming on for up to 15 mins every hour. We wild camp for long periods and in summer it's not a problem as we have 200w solar and usually plenty of sun to keep our twin 78ah gel batteries (and cab) nicely charged up, however over winter in southern Spain we got too low for comfort at times. We've been looking at various ways to improve this and after weighing everything up we've bought a genny to supplement/charge up as required - we have chosen this method as it gives us the ability to use some electric gizmos if we want to (Remoska etc). I'd rather have a 3-way fridge but for the PVC we wanted it wasn't an option.I would not buy a MH which had to rely on solar for its fridge and all other electrics in winter in N. Europe.
I think I'm right in staying that the Vitrifigo ones are the 'best' compressor ones out there for low power consumption and performance generally, but are you saying you can't turn it off on the panel on a night? Surely it has an on/off switch?I can only go by my own experience, we have a Vitrifrigo 60 litre compressor fridge.
I am thinking of fitting an inline switch so I can turn the fridge off overnight in winter as we don't use heating whilst sleeping and this would conserve more energy.
All in all, I find the Vitrifrigo to be an excellent fridge and we are very pleased with it.
We have 2 x Trojan T125's giving 240AH. We can run the fridge for 3-4 days
As a very rough estimate, you need about 50w of solar to sustainably support the fridge on sunny summer days... And lots more than that when it's cloudy and off season.
Mmmm. Rather than guesstimates, I'll actually look up some figures...
According to the manufacturer, the Vitrifrigo C60i uses 0.32kW/24h... I assume they mean 0.32kWh per day? Battery charge cycles are about 85% efficient, and manufacturer claims always assume ridiculous best cases, so lets assume you actually open the door a few times and you live in the real world, so you need ~0.5kWh per day from the solar system to keep the fridge going.
As a sanity check, 0.5kWh is about 42Ah (500vAh / 12v) . .. but remember you probably only get half the rated capacity of your battery if you don't want to deeply discharge it. So that roughly tallies with your 3-4 days claim, assuming you don't use much power on anything else.
As a rough rule of thumb, to work out your daily energy income on a sunny summer day, you take the rated output of the solar panel and assume it manages that for an average of 4 hours per day. 500Wh / 4 hours = ~120w
So yes, 200w of panels will easily keep you going through the summer. Winter sunshine is considerably weaker though... when we have any at all. It'll probably stretch out to needing to charge about once per week???
... and if anyone spots the errors in my calcs, please correct me!
Yes and no ... we used to worry about the door covering the vents when we had a 3-way fridge however there was still quite a gap so it didn't prevent hot air escaping and cooler air getting in, however it was actually a bonus because we used to put that side of the camper facing the sun and the door actually shielded the vents and outside of the camper from the sun giving it more 'insulation' from the heat.The problem with fitting an absorption fridge to a pvc is finding somewhere to put the vents so they're not covered when the door opens.
