Fridge running 12v
Messages
39
Deepest Kernow
Don't own one yet
Ok, we have an Electrolux fridge of the 240v / 12v / gas variety. We have run it on mains for a few weeks, and the gas seems to work, but not truly tested it yet.
When we come to running it on 12 v, I believe that some only run when the engine is running, is there a way to check this?
Also, forgive my ignorance, should it be started at 12v with or without the engine running first?
scotjimland
Messages
32,020
I assume you have the older model of fridge like mine.. ie manual energy selection and not the later AES (Auto Energy Selection)
On 12v battery selection it will only work when engine is running.. select 12v then start engine.. it doesn't matter whether you select before or after you start up.. it won't draw current until the engine is started.
take it for a run, but it will take a while to feel the cold on the evaporator plate..
Before a trip I pre-cool ours on the 240v overnight, then switch to battery when before setting off.
when you park up.. return to gas or 240v if on EHU
DBK
Messages
13,016
Plympton, Devon
PVC, Murvi Morocco
I've recently discovered on here some MHs can run on 12 volts with the engine off but I think most don't. If yours is the latter type, which is most common, you can switch it to the 12 volt setting then start the engine as the feed to the fridges will be controlled by a relay which won't close until the engine is running.
If your fridge can run off the leisure batteries you should be able to easily tell - turn it on and see if the volts drop significantly.
Otherwise apart from getting a voltmeter out and checking the feed to the fridge I can't think of any way to check if it is working with the engine running other than going for a long drive. :)
(All as Jim said - slow typing :))
scotjimland
Messages
32,020
yes, me also.. everyday day's a school day :)
As far as I know it's on later models that can use surplus solar energy. .. waiting to be corrected ;)
funflair
Messages
11,327
Guisborough
N&B Flair 8000 IVECO
since 2012
Ours is 2005 build N+B and runs of the leisure batteries, Dometic RM7605 model.
Martin
SMC Motorhomes Newark
RoadPro
Johns Cross
Safeguard Motorhome Insurance
Rhino Installs
Friendly professional service from qualified technicians
Free Club Stickers
Dave Newell Leisure Vehicle Services
