If like us you find your fridge is not working too well in Spain or other hot places it's because it is rated to work in the UK. There are four (CEN Standard) Climate Class ratings.
Fridges rated 'SN', and 'N' (which stands for Sub Normal, and Normal respectively) are designed and rated to work up to 32 degrees C.
Fridges marked 'ST', (which stands for Sub Tropical) are designed and rated to work up to 36 degrees C. Those marked 'T' (which stands for Tropical) are designed and rated to work up to 43 degrees C.
A correctly installed fridge Climate Class rated fridge can be relied upon to work satisfactorily up to the highest ambient temperature for which it is rated. But once past that temperature, cooling performance is likely to drop off.
This is something to bear in mind if you spend a lot of time in hot places and have to replace your fridge like we have to. UK gets rated SN you can find the rating on the sticker inside the fridge.
