Fridge problems
Autotrail Dakota
Third time out in Autotrail Dakota
The fridge is working well , I decided to turn it down to 2 lights and now it appears to be stuck there. I can’t turn it up or down
Any ideas
Chris
Any ideas
Chris
Just try switching off completely and after a couple of minutes back on that should reboot it😊
On my fridge the thermostat knob is connected to the rotary control on the circuit board by a thin rod of yellow plastic. When I bought the MH (it was a few years old) the thermostat had the same problem that you describe.
If you pull off the control knobs, there are some screws holding the front panel. I seem to remember it was possible to replace the broken rotary connecting rod. That was a few years ago, and I think that once set, I've hardly adjusted it at all in all that time, so I'm not sure I'd bother if it broke again.
