Fridge over cooling, freezing everything
Uk
I have a problem with my Electrolux RM4401 fridge in my 2001 B584, normally people have a problem with fridge not get cold enough,well mines the opposite, it’s freezing everything..
Last year it wasn’t working very well so I removed and cleaned the jet and in my wisdom thought I would use an airline (only gently) and blow back up the pipe , so I removed pipe from manifold under sink and blow up pipe.
I think in doing this I must of damaged something in the gas valve because no matter where I put dial the fridge is way to cold, fins covered in ice😒
I’ve tried a different jet and it’s still the same, I did notice the thermo couple tip is burnt but I think this just keeps the gas valve open.
Any suggestions
tonka
Cannock, Staffs
A class Burstner 800
Since 2000
My first thought is the thermostat, keeping the fridge on and not cutting out once temp reached.
Manic
Uk
Has the thermostat failed Nick and now not controlling the burner?
We had the opposite with one of the ovens at home where it was flat out heat whatever the temperature was set to, I fitted a new thermostat and all good now.
That’s my suspicion but where is the thermostat, I can only see the gas valve with control knob and the thermo couple.
Stealaway
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Any suggestions
Try a search for a thermostat -- Electrolux rm4401 refrigerator thermostats.
JockandRita
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Is the thermostat plugged in to the fins plate, on the interior back wall of the fridge.
I seem to remember having to remove it, when I renewed the heat sink gel.
Jock. :)
Manic
Uk
Jock. :)
That’s for the 240volt side of things.
tonka
Cannock, Staffs
Since 2000
I'm with Jock, it's on the fins at rear of inside of fridge. Google it and you will see what it looks like.
Lincolnshire
PVC
30 years
In which mode does it over-cool? Is it gas, 240v or 12v operation?
Geoff
Lincolnshire
PVC
30 years
I would have thought it would use the same thermostatic switch for both gas and 240v. Perhaps they are independent devices. Have you looked for spares for this particular fridge, do they list two separate thermostats?
Geoff
Manic
Uk
Well I’m happy because I haven’t got to sort fridge, it’s sorted it’s self.
Something must have been stuck because it’s working fine now.
Manic
Uk
Manic
Uk
So pleased I posted twice, but not internationally, internet speed is good but seems slow😒
