Fridge not working on anything (1 Viewer)
Jul 2, 2014
204
720
Leeds
Ih tio
Not used van since September tryed fridge it’s dead it’s a Dometic 3 way fridge it’s 15 years old rang a repair place they can’t even look at it until July any ideas what i can try .is it time to get a new one .gas and electric are working on everything else but not fridge thanks
Dec 24, 2014
9,212
47,552
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
New fridges are very expensive. Since yours doesn't work on anything I think it's extremely unlikely that yours needs replacing completely.
As M-J has said; check fuses and more info needed.
On gas the fridge needs 12v for the control unit and igniter. Do you hear the igniter clicking?
Jul 4, 2018
1,208
1,588
Bristol
Weinsberg
A few years.
What pappajohn says, time for the multi meter and Sherlock Holmes investigation, which will be cheaper than a new fridge.
Dec 24, 2014
9,212
47,552
Compass Navigator
Check through the guide, starting with the Troubleshooting page in the manual for your fridge.
(The 'L' in the fridge number just means Left hand door).
SandraL
1,373
985
Somerset
Hymer b694sl
Does this thread help? Post no3 in particular re the gas.
Can you check for 12v supply at rear of the fridge with meter, the thin cables not the thick 12v element supply cable.
jako999
304
785
Halesowen
Niesmann Bischoff
If it’s stood make sure everything is off and 240 disconnect remove all the contacts on the rear control panel one at a time and clean them spray all the micro plugs and replace. Even after a couple of years they stars to fur up.
worth a try
68c
Oct 22, 2019
1,816
2,792
Southampton
2001 Pilote 270
Since 2004
When selected to gas can you feel any warm air coming out if the exhaust duct? With the bottom cover removed can you see if the small flame at the bottom of the large tube is lit! If you have the flame and warm air is felt it is likely the gas/fluid mix has leaked rendering the fridge scrap
Phil 748
246
272
Newark Notts
AS Nuevo ES 06
Hi here is a copy of the wiring for the RM 7XXXL Series, connection points x105 is 12V, and x101 is 240v, hope this helps
  • Fidge.pdf
MaryR
3
Fiat ducato van
Hi, we have just bought a van with a Dometic RM8401 fridge. It all seems ok on the panel but just doesn’t get cool! Gas chills slightly but not enough to keep food safely. 240w just doesn’t chill at all! Any advise please? Not sure where the fuse is to check that?
mary
Nov 5, 2019
900
1,761
Arkley, Barnet, UK
Corinium Duo
Relative newbie
Was there a fix for this? My fridge has just died too, all fuses are fine, going to get the multimeter out...
Jul 17, 2022
adria coral
Yes mine has gone too Rm 8501 gas not working no electronic ignition was fine last year the clicks got slower and very random
Nov 18, 2011
11,862
42,915
Planet Earth
A van
Over 25 year's
Our fridge after two years dormant would not work tane it out turns it upside down a few times then put it back in 24 hrs later tryed it working ok now that's a 32 year old one
Bill
Jun 25, 2021
414
1,169
Nottingham, UK
Hymer A class
Did that over the weekend with my little beer fridge,havnt used it for five years not working,after turning upside down for a couple of hours, then let it settle over night ,bingo👍
