Thank you another one to check tomorrow ! Keep them coming pleaseOn our Burstner, on a Fiat base,, there is a 20 amp fuse on the +ve terminal of the engine battery that protects the 12v to the fridge.
So far sorry but haven’t found the problem so we plod on !!Note; continuation of old (July 2018) thread.
@spitfire did you resolve the problem? My Dometic fridge won't work on 12v - on auto select it just switches to gas (no hookup available just now) and if I try to select 12v manually the fault code shows no engine running signal. 2007 Ducato 130 multijet by the way.
The fridge manual just says change the fuse but none of the Fiat manuals give me a clue as to where it might be. I'm going to check the battery terminals first, as per above, but there's three more fuse boxes, not to mention several relays. I had the fridge out a couple of months ago so I'll recheck those connections as well.
Anybody got any other ideas? I know from @PhilandMena post that it could be the 12v element gone but I can't tell if it's working or not because the fridge won't let me select 12v.
In N. France at the moment butI'll be home in the next couple of days so it's not a big problem. However if it's a simple fix then so much the better.
They won't, its nothing to do with Fiat.none of the Fiat manuals give me a clue
