I have 3 x 80mm on a plate below the fins. I mounted a fixed thermostat of the value, and in the position, shown in the Dometic kit instructions (mine is NOT a Dometic kit). They switch on and off as (apparently) required. I have an thermometer permanently fitted with the sensor on the fins under the freezer compartment. In south UK at present with outside temperature averaging 23/24 midday & fridge achieves 1.2 degrees C in the morning rising to 5/6 during the day dependant on number of times it's opened.We've found performance also improves when you have less in the fridge.
When we gat back home I'm going to see if it's possible to mount the external fans horizontally, directly above the cooling tube for even better circulation.
