If you look closely you will see how cold it was up here today.
Working well so far,got them on eBay. Look like the same as @Les from Suffolk has given a link to. I have had to up the ambient temperature and move the module away from the gas exhaust as it was getting cooked.How is the temp controller working for you ?? any chance you could link where you bought it from
Estimated delivery on the fan is upto 28th December
True... But not Amazon prices either..Estimated delivery on the fan is upto 28th December
Hardly Amazon Prine
I’d rather pay a pound or two more rather than wait until nearly next year for deliveryTrue... But not Amazon prices either..
It may just be the perspective but why didn't you fit the fans lower down in front of the fins?View attachment 182672 Finished installing my fridge fan kit today when I wired up the digital temperature controller,set it to go on at 35c and off at 31. Hopefully it will come in handy when we head off for our 3 month Run To the Sun on Monday.
Fairly standard to fit them behind the top grill, most of us just cable tie them to the grill.It may just be the perspective but why didn't you fit the fans lower down in front of the fins?
As @Lenny HB has said the standard location is just behind the top grille so I fabricated a bracket that placed them there. I didn't want to fix them to the grille.It may just be the perspective but why didn't you fit the fans lower down in front of the fins?
Did mine exactly like that, easy peasyFairly standard to fit them behind the top grill, most of us just cable tie them to the grill.
Like mine.
That's the theory, warm air rises and all that. On our van, which is a PVC, the grills are in one of the back doors but they are some distance away from the back of the fridge. If I had fitted my fans to the top grill the cold air would come in the bottom, scoot straight up, missing the fins of the condenser more or less completely. So my fans are much closer to the condenser and the temperature sensor it about an inch or so above the fins.I take it the idea is to have the two fans pulling the hot air up through the TOP grille vent away from the back of the fridge ??
Also where is the best place to mount the temperature sensor for the two fans?
Exactly my thoughts, PCB boards and moisture don’t mix well, for the cost (£3) I would place it in an small enclosure to protect it from the elementsPresuming you are not putting the circuit board in a case, hope no-one ever get over excited with the hose pipe when washing it and squirts water up thro your vent.
here are the instructions to the one I used for my internal fan should be the same.I have the same controller ready to fit in our moho but it didn't come with instructions. The Chinglish version on the ebay listings doesn't make it clear how to set the start/stop temps or explain the other parameters (P0 to P6) that come up when the Set button is pressed and held in for a few seconds.
Does any kind soul have a link to the info I need, please?
I noticed in my DL the area behind the fridge runs hotter that it was in the Exsis. Same fridge, identical installation, only reason I can think of is the burner/jet assembly has been changed in a effort to make them work better. If so they didn't do very well did they.Presently on site at Haro in Spain it's rather a cool morning at 14.2 deg indicated temperature (sensor mounted above top evap fins)with fridge running on mains power is 29.4 deg, it's an eye opener just how hot is does get in the upper part of this space no wonder fridges struggle in warm weather.
It's amazing the difference the internal fan makes to internal temperature spread and how much quicker the fridge gets back down to temp after opening the door. If does make the fridge work harder, on the last trip in September use of heating was about the same maybe less than other similar trips but we used more gas, used up one bottle (28Lt/14Kg) in 18 days normally lasts us 21/22 days.I copied Lenny's installation both on the exterior and interior fans the results have been brilliant with the fridge running a constant 4° . So a big to Lenny
