Fridge bleeping when on 12volt with engine running (1 Viewer)
Sep 1, 2007
53
22
Guildford
Van Conversion
since 2004
fridge works on 240 and gas in my devon camper but on 12v it just beeps the fridge is a DomenticI Have looked for fuse in battery compartment all fuses that i know of seam good unless there is another one hidden away any help would be greatly accepted cheers Lawrence
Lawrence
Sep 1, 2007
53
22
Guildford
Van Conversion
since 2004
thanks for coming back to me would that be a an intelligent split charge unit or would that one be for splitting charge between batteries any idea what the relay looks like
43,286
49,216
I would expect it to be a standard 12v 30a automotive relay.
Split charge would be by another, identical, relay and independent of the fridge relay.
Both are usually close to the engine battery.
Falcon 269
381
1,335
Melton Mowbray, UK
Might also be as simple as a poor connection or dislodged connector. We had a 12v warning beep come on every time we cornered in our Adria immediately after it had been in to have a solar system installed. Turned out that the power feed to the fridge had been inadvertently disturbed and this led to intermittent loss of power.
Lawrence
Sep 1, 2007
53
22
Guildford
Van Conversion
since 2004
thanks i will follow up on that cheers
Lawrence
Sep 1, 2007
53
22
Guildford
Van Conversion
since 2004
thanks i have now found the relay thanks to your pic, i will get a replacement see how that works cheers
Lawrence
Sep 1, 2007
53
22
Guildford
Van Conversion
since 2004
Thank you for your help it looks like it was a connection on the battery split charger relay all working well now, cheers Lawrence
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Ppj, thanks, this is exactly what makes this such a valuable resource as well as a great forum for a laugh.
