normanandsue
In all the years of motorhoming I have never cleaned the fresh water tank. Should I and if so how often and what with
Depends on a number of things as you most probably know. If you use the system full time and are constantly running fresh water through the system, then most probably never.In all the years of motorhoming I have never cleaned the fresh water tank. Should I and if so how often and what with
I bet it does pong a bit, it's meant to be 1 tab to 25lts of waterI use the AquaClean tablets PP Bear mentions above about once a year or so. I don't trust the water coming out of taps in faraway places. We filled up at a place in Provence and there were leaves in the water! The tablets do make the water smell "chemically" but until that goes we just fill the kettle from bottled water.
You can buy them from Go Outdoors very cheaply and use a one tablet per 5 litres I think. Just push the tablet into the filling intake and flush down with a hose. Give them a while to dissolve then run the taps so the treated water fills all the pipes. You will smell it when it comes through.
Leave overnight then drain, refill and flush if you want, or just use the water normally.
So that's where he isBut we never use it for drinking water anyway. Apart from Elvis.
