fresh water discharging
Farnham surrey
Swift Kontiki 794
I'm a newbie
Good Morning All, we have a 2026 kontiki 794 & this morning on site we heard water running out from the rear of our vehicle so to stop it we have to turn the pump off, so can`t use our water system unless we we turn it back on & have water gushing out from the rear, very disapointing as it is only our 2nd trip.
It could be the valve has creeped open, we had same issue. Try cycling the valve open and shut. If this doesn't work there's a little round nob on top of the valve, pull this up and twist you will see and hear the value operate. Look in the pipe and you should see the position of the valve
Sounds like the automatic frost valve has done what it's supposed to and released the water to prevent damage.
Trouble is they can be sensitive to the temperature which is why some of us have a gadget (peg or cable tie usually) to stop it happening.
Just have to remember to remove it when you're not monitoring the weather and/or not using it overwinter.
Have a look on a weather app and check what the temperature overnight was where you are.
To avid the frost valve tripping, without having to remember to remove pegs/cable ties et al, we leave the heating on overnight at 13 degrees when we're using the M/Home; that gives a decent safety margin but is still cool enough to sleep - the 0300 bathroom trip is not one where we want to hang about and luxuriate in the sub-tropical temperatures [because 13 degrees is closer to pure Baltic ...] :ROFLMAO:
Just to add that the frost valve protects the water heater and is usually ( but not always) right beside it. It should be in your user manual. On our current van, it's impossible to see the button on the back. Assuming it one of the normal one, to be closed, the top knob needs to point across the length and not along it. Then find the smooth button down the thin curved side and push it in. You will feel it latch.
To force a drain down, just turn the top knob 90 degrees and let it drain. Reset it all before you refill.
Hi, Would you know where abouts the frost valve is located, thanks
Must have had a comprehensive handover 🙄 ,It'll be inside the van above where the water was coming out,
Papa lazaroo says that the turning the pump off stops the flow. That suggests a leak to me, not a sticking dump valve.
Genuine question, but why do you think that?
My logic is if the valve has already opened, it will have dropped the water in the boiler and stopped there. When you turn the pump on it tries to refill the boiler and just runs straight through and out of the drain valve? I can't be the only one to have forgotten to reset it and carried water to refill the tank to then turn the pump on and lose some of what you have just carried onto the floor? :doh:
I totally follow your logic and on a Truma based system would be highly possible as a cause for the problem.
The Swift Kontiki has an Alde boiler rather than Truma and as far as I know those dont have a frost drain - only the manual yellow taps. That motorhome does have an automatic frost drain on the freshwater tank (I think) so that was the one I assumed others were referring to. That one of course would not be influenced at all by the pump being on or off.
Edit: Just noticed OP refers to Kontiki 794 in original post and Bailey Autograph 79-4 in their profile! Whichever it is, I think they both have an Alde boiler so my logic holds!
