Fresh water access on G740 (1 Viewer)
Jan 20, 2019
844
1,858
Bristol
Pilote G740
Since 2019
Hi All
Would like to remove the end of the hose that came off whilst filling with water from my fresh water tank:crying:
Not had a proper look yet as I’m away but would I find access under the van?
thanks
Dec 30, 2015
1,427
1,264
Bury
Pilote G650L
Three years
Hi All
thanks
You might get a bit wet if you try to access it from underneath. :giggle:
Jan 27, 2018
829
1,703
Aberdeenshire
low profile
Not sure of your model but if G stands for garage your tank may be in there. It's where it is on our 700gj.
AG 2602
Jan 20, 2019
844
1,858
Bristol
Pilote G740
Since 2019
Thanks All
I’ve found it under a drawer located at the end of the bed. Got my had in but can’t really access the whole tank so no joy.
Last van had a tank with a plug if you needed to drain and you could basically feel around the entire tank!🤔
AG 2602
Jan 20, 2019
844
1,858
Bristol
Pilote G740
Since 2019
Thanks All
*hand!
May 14, 2014
614
742
Now a little one
Unless they have changed the design of the G740 with the island bed, access to the fresh water tank is gained by removing the two drawers in the bed end nearest the washroom. With the drawers out, there may or may not be a lift out panel in the floor and the fresh water tank threaded cap will be visible. Bit of a hands and knees job but doable and it gets easier each time you do it.
Hope this is of some help.
AG 2602
Jan 20, 2019
844
1,858
Bristol
Pilote G740
Since 2019
I’ve managed to locate the tank and found the plug so now I know how to drain it down.
No sign of the hose fitting but it’s a difficult tank to feel around.
I think if I put the front up on levellers then it may float towards me. Failing that I’ll leave it bobbing about! 😂
It was a COVID handover when I collected the van and not had chance to go over everything but we’re getting there!
Thanks again😂
The Coops
1,810
34,206
The Fylde
Adria Compact DL
Yes, thank you
Why not see if you can borrow one of the inspection type cameras and see if you can see the fitting? It may be in the filler tube and not the tank, don't ask me how I know!:rolleyes:
