Fresh water access on G740
Bristol
Pilote G740
Since 2019
Hi All
Would like to remove the end of the hose that came off whilst filling with water from my fresh water tank:crying:
Not had a proper look yet as I’m away but would I find access under the van?
thanks
No it will be in the top of the tank probably inside your van under a floor trap😊
Hi All
thanks
You might get a bit wet if you try to access it from underneath. :giggle:
Not sure of your model but if G stands for garage your tank may be in there. It's where it is on our 700gj.
Thanks All
I’ve found it under a drawer located at the end of the bed. Got my had in but can’t really access the whole tank so no joy.
Last van had a tank with a plug if you needed to drain and you could basically feel around the entire tank!🤔
Thanks All
*hand!
It’s a Pilote G740 with fixed double at the back.
Unless they have changed the design of the G740 with the island bed, access to the fresh water tank is gained by removing the two drawers in the bed end nearest the washroom. With the drawers out, there may or may not be a lift out panel in the floor and the fresh water tank threaded cap will be visible. Bit of a hands and knees job but doable and it gets easier each time you do it.
Hope this is of some help.
I’ve managed to locate the tank and found the plug so now I know how to drain it down.
No sign of the hose fitting but it’s a difficult tank to feel around.
I think if I put the front up on levellers then it may float towards me. Failing that I’ll leave it bobbing about! 😂
It was a COVID handover when I collected the van and not had chance to go over everything but we’re getting there!
Thanks again😂
Why not see if you can borrow one of the inspection type cameras and see if you can see the fitting? It may be in the filler tube and not the tank, don't ask me how I know!:rolleyes:
