ford ranger wont start
In the van
A van
Over 25 year's
I have a ford ranger it bean off the road for a few years it turn over but wont start new diesel and oil in it i think it's the mobilizer dose any one kow how to reset it bean sting with out a battery
bill
I have an old Mazda B2500 double cab pickup truck. It is exactly the same as the Ranger, just a different badge on the grill. As far as am aware it doesn't have an immobiliser. they are a bit of a bitch to bleed up though. I have to use a bleeder pump when doing a filter change. The stand pipe from the tank is also susceptible to rotting and drawing air.
Wonder if the injection pump seals have dried out Bill.
Never worked on that engine so don't know if it's common rail or mech pump.
Might also have diesel bug in the tank and lines
meck pump john the lines are clean as far as i know the was no diesel in the lines when i lade it up but i did keep the pump wet its just not getting diesel to the pump seeps like the solinoyd is not working and lift pump not kinking in
bill
i will try and use a bleder pump ont it tomorrow but i think the solinod on the injector pump is not working not geting power to open it has a aftermarket security system i had fitted but the company are no longer trading
billl
Can you take the stop solenoid out and bench test Bill.
You could confirm the lift pump with it out too... Bit messy if fuel does come out the hole but you'd know if fuel was getting to the pump or not.
Even attempt a start without the plunger in place in the solenoid. You need to stall it of course if it does start.
Had to do that on an old diesel escort van once to get home when the solenoid failed.
its sealed integral unit john lodes of weirs got a auto spark coming out tomorrow it a 04 plate he recon it has a factory immobiliser fitted I don't know and cant remember what I had when I bought it I do remember changing a battery once and having all sorts of bother but back then I just called my fitter to sort it out
bill
i was let down today by the so called auto sparks think he was just a bit of a chancre i sent him on his way after abut ten min
bill
bill
Sorry bout that Bill ... loving the avatar Jay .. aunty Joy :)
Jay is growing up at quite a speed Bill, he's looking well & gonna be a heart breaker, the girls will adore him.
Robert.
His Aunty Joy adores him too.
Get down to your work at school Jay ... one day you will be a leader in your chosen path. X
