Ford (Chausson) Cobra disable internals? (1 Viewer)
Steve and Gill
36
23
South Warwickshire
Wildax Constellation
Two Tours around New Zealand
Anyone mastered the locking of the Cobra alarm from inside with the internal sensors disabled?
Can't get ours to lock without alarming despite seeing the single flash from the dash led.
sdg
2018, Ford Transit base, Chausson 630.
Feb 13, 2013
984
1,057
Edinburgh
Rapido 881F
Since 2015
We have a switch that we use to disable the internal sensor and then we just activate the alarm via the central locking fob.
We know it works having forgotten to switch it off before enabling the the alarm as it makes a hell of a din when you move!
Steve and Gill
Steve and Gill
36
23
South Warwickshire
Thanks, this system has a press button on the dash which should do the same, just can't get it to have the doors locked with us inside.
Instruction sheet say Vodaphone 46xx
Looks the same as the Cobra alarms.
sdg
Sep 1, 2017
222
85
On my Cobra if I press the alarm fob to arm and then press the same button again it disables the interior ultrasonic sensor.
Jan 11, 2018
1,156
1,337
Malvern Link, Malvern, UK
Chausson Welcome 85
Since 2018
If it's like ours (a Corbra with the tiny button thing on the dash), you have to press the button until the little indicator gives a long flash (usually only a second or two), but you must do this within 5 secs of turning the ign OFF.
You then lock with the remote fob button.
The 5 seconds thing foxed us at first.
Steve and Gill
Steve and Gill
36
23
South Warwickshire
Thanks Jake - that is how ours is set up - possibly just finger trouble as it was ok the last time we tried it.
If the alarm has been triggered it appears to need a lock and then unlock to get it back into a normal state.
sdg.
Steve and Gill
Steve and Gill
36
23
South Warwickshire
Success!
Just need to remember to unlock with the keyfob and open a cab cab door before going out via the hab door :)
sdg
