Any thoughts? Water pump just stopped working. Fuses seem OK! How easy to remove, test and replace? Suggestions? It's a flojet pump. Is it a DIY job? Difficult to get repairs with covid restrictions.
You can(could?) get parts for some pumps, but by the sound of it you need a new one. How hard to replace depends on location? Normally 2 electrical connection and 4 bolts or screws
I've had replacements off 'tinternet not cheap and you need to know the flow rate and the set pressure as there are different capacities. You can substitute other makes of pump as long as the specification is the same
Showing on Amazon at about 60/70 quid(ish) Johns cross also show and I think he does a funster discount?
Thanks, pump very easy to access. Have followed instructions to remove ie, pull down to blue clips at right angle to pipe and remove pump. If only it were that simple. Yes, pulled blue clips down but can't seem to get pump to release.?
