Fleurette Wincester Opinions (1 Viewer)
Jan 7, 2023
274
352
Bath, UK
Fleurette Wincester
Since Jan 2023
Hi - first time poster here, and nearly a first time motorhome owner.
I'm after some opinions on the Fleurette Wincester (2021) 75LMF. It looks fabulous, but as a first time buyer I wondered if there was anything specific to this make/model I should be wary of?
Thanks.
Riverbankannie
10,139
58,866
Bristol
IH 630 RL PVC
:hiya:
The main problem seems to be that it is not usable due to no payload.
daventess
Jan 7, 2023
274
352
Bath, UK
Fleurette Wincester
Since Jan 2023
Hi, and thanks for your answer. That was something I didn't even realise I had to look out for.
I obviously need to research this, but briefly does this mean the thing ways only 291kg short of the 3.5T limit for my driving licence?
Lenny HB
50,292
138,949
On the coast in West Sussex
Hymer B678 DL
:welco:
You can't in real life run vans of over 7m at 3500kg certainly not an A Class. If you want an A Class van and want to keep to 3500kg you need to be looking at sub 6.5m vans even then it will be difficult
Our van is 7.5m and has a payload of 1350kg on a 4500kg chassis. I wouldn't entertain a van with less than 700kg payload.
1,618
3,736
mid-Norfolk
since 2006
YES!
Another thing to consider with the Fluerette is the number and position of the 240V sockets: we weren’t impressed.
If it has the convertible seats for travelling passengers, check that you are happy with how they operate.
Gordon
933
935
Malvern
Hymer B525 2006 A cl
Briefly - yes.
Slightly longer - 291kg payload is almost certainly an optimistic estimate as most models will have extras fitted that will reduce the payload by whatever they weigh. For example an automatic gearbox will likely weigh more than the manual but the payload will assume you have the manual model. Likewise add in extras such as awning, solar panel and you will have no payload left.
As the driver you will be responsible for driving a vehicle that weighs under 3500kg ( if that's what your license limits you to) or face the consequence.
Have a search on here for threads about payload, it's a minefield I'm afraid.
daventess
Jan 7, 2023
274
352
Bath, UK
Fleurette Wincester
Since Jan 2023
Thank you all for your responses.
I actually have a C1 licence which i think allows me to drive up to 7.5T (I need to check that).
So is the 3,5T limit only for the driver's licence (in which case I'm ok) or does the vehicle itself have a max. weight of 3.5T?
I've asked this without researching myself, but I'm going to do that as well now...
Langtoftlad
8,552
140,474
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
Yes it does... but you can up rate most vehicles... either as a paper exercise, or by fitting rear airbags or wider tyres. The taxation class also has to be changed at the DVLA.
We'd need a pic of the vin plate to advise the potential.
daventess
Jan 7, 2023
274
352
Bath, UK
Fleurette Wincester
Since Jan 2023
Thank you for this. We haven't bought the MH yet, so I don't have that info.
Thank you to everyone who has responded. I clearly have a lot to research and learn!
2,859
4,460
North Somerset
No longer own one
September 2020
Take a look in the Resources section, you can download the Buyers Guide. There is also advice on Payloads etc.👍
Barchetta47
112
349
Burstner i681
Since 2018
If you are looking at the Winchester on Autotrader it is taxed at 4400kg. I would imagine the payload would be sufficient.
daventess
Jan 7, 2023
274
352
Bath, UK
Fleurette Wincester
Since Jan 2023
Hi - yes, I am looking at that one. Where did you find mention of 4400kg? I can't see that anywhere. I can see it mentions 4.4kg payload. Is there a way to find this info out independently?
edit - ah yes, on the gov.uk site (https://vehicleenquiry.service.gov.uk) I can see it's taxed weight.
So does that mean it has been uprated to 4.4T, and is safe to load up?
933
935
Malvern
Yes, and with your C1 you can legally drive it.It will be the GVW that is 4.4ton. not the payload but the payload will probably be in the region of 900kg
115
309
Beverley, UK
Florium magister74ml
Been caravanner for over thirty years,now going to have motorhome very soon.
Briefly - yes.
We have a magister 74MLF when we purchased it new last august the first thing we did was weighed every item we put in ,filled it with fuel and tootled off to the weighbridge and we had 250kg to play with for food and any extras ,but its only used as a two berth and one small dog.
so it is doable.
daventess
Jan 7, 2023
274
352
Bath, UK
Fleurette Wincester
Since Jan 2023
Thank you to everyone for your input. It's been really useful. And as it's been confirmed as uprated to 4.4T, we're going to go for it as we believe there is more than enough payload for 2 of us.
Cheers, all!
929
4,888
North West
Florium Wincester
Europe & USA since April '21
We have one. Standard payload is poor like every other A class with extras at 3500. Pm me if you'd like a chat about the van.
daventess
Jan 7, 2023
274
352
Bath, UK
Fleurette Wincester
Since Jan 2023
This one has been uprated to 4400kg, so we're hoping that gives us over 1000kg though we'd probably need to weigh it unladen to be sure. It has got a lot of extras on it (inc. a second battery, which can't be light).
(I've also responded to your PM).
