Because it’s not connected to your hab controls or solar panel.hi my starter battery was flat today, although I have an ec700 control panel and 100watt solar panel.
how has this happened
Fiat Ducato x290 2019 model apache 634
any ideas guys
Battery master.Can someone please explain to a numptie what I need (b2b? dual solar charger?)
I've searched ebay for these and its not helped
Usually when you arrive home or at your destination, the starter battery is fully charged after a long drive. You probably have something that keeps your leisure battery charged (solar panels, ehu and mains charger, etc). Often, however, it isn't wired up to keep the starter battery topped up, and it goes flat after a few weeks. What you need is a Battery Master, which senses when the leisure battery is charging, and diverts a small charge to the starter battery. If the leisure battery isn't being charged, the Battery Master disconnects it from the starter battery. Fit and forget.Exactly the same thing has happened to me today on my Swift Bolero 612 (2018). I have a 100W solar panel and the starter battery is totally dead after 6 weeks off mains.
I've searched ebay for these and its not helped.
Actually the Swift information panel can toggle between hab and vehicle battery info.Your solar panel should be connected via a solar regulator to the electrical control unit which should already have the smart solar charging control feature which can be set to charge either the habitation or starter battery or both as required.
Most b2bs take care of alternator charging of the leisure battery but not the engine battery. Some of the Votronic ones do have a setting for trickle charging the engine battery when the leisure one is full.Because it’s not connected to your hab controls or solar panel.
You need a b2b. Battery to battery controller that keeps your starter battery topped up.
Are you sure about this, or perhaps just guessing.Because it’s not connected to your hab controls or solar panel.
Bet you regret asking this question, some members have already spent hundreds of your pounds on solutions that are probably not required. I too have an Autotrail although a bit older than yours I suspect but never the less, my Sargent system looks after both sets of batteries (I also have Solar Panels fitted) and in my case its automatically done. You don't say where you are and I suspect your in the UK and at best pulling just over 1 Amp from the panel which is possibly being fed to the leisure battery. Others have said with your model you have to select which battery is charged from the solar and this may resolve your problem if the wrong batteries have been selected. Also, you possibly have a small drain on your cab battery from a security system ? When I start my engine, my alternator will charge both my leisure batteries and cab batteries. (I only found this out after fitting a battery monitor) and this may well be the same for you. Get a multi-meter on your batteries with your engine running and see if this is the same for you. An option you might want to consider if your vehicle is parked up for a long time over winter is to simply fully charge the cab battery then disconnect the negative cable and your battery will not drain. This link may be helpful.hi my starter battery was flat today, although I have an ec700 control panel and 100watt solar panel.
any ideas guys
After reading the instructions for my EC620 unit I would bet that your EC700 unit will automatically vary the charge between batteries from the solar panel when not plugged into the mains. I would recommend downloading the instructions from Sargents website if youve mislaid yours.I thought the ec700 took care of all the switching from hab to cab without additional devices (B2B)etc
I’m not sure what the settings on the ec700 for instance smart settings for cab and hab batteries
Utter Cock ! Get rid of him.We used a new service guy last October having needed to get a hab check and various other repair works put in place. Imagine my surprise when he said we should NOT have the charger unit engaged/enabled when the van is sat at rest, on hook-up and with a solar panel to boot.
You might want to read post #18.I would recommend downloading the instructions from Sargents website if youve mislaid yours.
Eek ... I somehow did think that was going to be the collective responseUtter Cock ! Get rid of him.
? Ooops!You might want to read post #18.
Don’t hold back..say it as it is! Very succinctly put if I may say so.Utter Cock ! Get rid of him.
