I bolted the bracket through the wall and into the bathroom cabinet and secured with penny washers and nutsWe’re did you mount tv?
I think this panel on right of toilet is best with swing arm bracket
I would recommend fitting a bracket that allows the TV to be removed for transport and also so it's not in the way and thus can't annoy you to death every time you go past it.I bolted the bracket through the wall and into the bathroom cabinet and secured with penny washers and nuts
It is out of the way and can be easily removedI would recommend fitting a bracket that allows the TV to be removed for transport and also so it's not in the way and thus can't annoy you to death every time you go past it.
Perfect that’s the bracket I’ve got with swinging arm demountable thanksI would recommend fitting a bracket that allows the TV to be removed for transport and also so it's not in the way and thus can't annoy you to death every time you go past it.
Was there any wires in panel , as switches are near there ?I bolted the bracket through the wall and into the bathroom cabinet and secured with penny washers and nuts
There was a live feed that I picked up inside the bathroom cabinet. I ran two new coaxial cables from the connection in the overhead sliding cabinet in the lounge area, down behind the side seats then through the back of the bathroom sink unit. I drilled a hole from under the sink through to the cupboard under the bed then ran them up in the corner behind where the tv was mounted.Was there any wires in panel , as switches are near there ?
What model do you have ?There was a live feed that I picked up inside the bathroom cabinet. I ran two new coaxial cables from the connection in the overhead sliding cabinet in the lounge area, down behind the side seats then through the back of the bathroom sink unit. I drilled a hole from under the sink through to the cupboard under the bed then ran them up in the corner behind where the tv was mounted.
