Riverbankannie
Promised description from husband. It will probably take a few posts to add the photos.
Fitting Pro-Plates to Fiat Ducati doors
I have just finished fitting Pro-Plates with studs to the manual locking doors (driver’s door and rear “barn” door) of a FIAT Ducato.
Although it wasn’t a difficult job technically, it was fiddly and frustrating especially the driver’s door because I was not familiar with the fitting of the door trim panels and how the door furniture was assembled. In both cases the plates fit under the door handle & lock mechanism which therefore has to be removed from the door.
You will need a set of trim removal tools, 10mm spanner I used a ring spanner and a socket on a ratchet extension, screwdriver(s) with pozidrive and Starr ends, and a 10mm clearance drill.
I’ll post separately for the two doors with photos.
FIAT Ducato Rear door
Remove the upholstered interior panel
(photo), how this is secured will depend on your van converter. In my van they were attached by self tapping screws
(photo), other manufacturers may vary. The FIAT door trim panel
(photo) was still underneath attached to the metal door by the original plastic clips. These are removed by levering out using a trim removal tool
(photo). These clips can be reused
(photo), but new replacements are available for purchase. I was able to reuse all of the clips I removed.
