Fitting new mains battery charger (1 Viewer)
Steve and Denise
5,287
14,081
Spalding LINCS
A Class Carthago
Since 2008
I have just fitted a new Victron 30amp mains battery charger to replace our Cbe 522 one as we have gone to lithium ( not wanting discuss profiles here)
Our old Cbe unit had a D+ Signal connection from the DS470, what I would like to know is why there was a D+ going to the 220v mains charger
Is it to disable the charger when you start the engine, if so should I fit a relay on the 220v input using theD+ as a signal.
I have sent an email to Cbe but had no reply as yet and thought others on here may know.đź‘Ť
Mar 25, 2021
185
267
Chippenham, UK
Chausson 610 Welcome
Ex Tugger saw the light in 2019
I have the CBE516 charger but mine isn't a D+ signal, it's a 12v supply to the DS300 to give an indication of EHU on the Hab control panel. I have gone down the lithium route and the CBE516 charger is disconnected. My votronic charger is connected in it's place. I could get a 12v supply to illuminate the EHU light on the panel but I really can't see the point. Prior to driving off during my walkround I probably would trip over the EHU cable:LOL:
Steve and Denise
Steve and Denise
5,287
14,081
Spalding LINCS
A Class Carthago
Since 2008
Thanks that would make sense though even with the signal wire disconnected the display still shows ehu so I won’t worry about it👍
Mar 25, 2021
185
267
Chippenham, UK
That's a bonus, mine system must be a bit more agricultural but like you not spending any sleepless night over it. (unless a funster posts to the contrary:giggle:)
andy63
4,672
15,017
south shields
None
since 1990
It was a while back..but from memory ....
If the mains was connected ..and you started the engine there was no d+/ engine run signal available to the cbe distribution board..so all the functions that relied on that wouldn't be present..
The white signal wire I'm pretty sure was responsible for operating a relay on my cbe board..but the only small issue I have with it disconnected is the indicator light on the panel doesn't work when hooked up to mains..
I left the cbe charger in place but connected it to the start battery as a dedicated charger for that..switched on manually when I want to top up the start battery..
Andy
Ps
Without that signal from the cbe charger to the power distribution board the new charger won't charge or maintain the start battery... hence me using it as a dedicated start battery charger...all be it manually switched
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Could the D+ be used to signal a warning if you switch on the ignition whilst EHU is still connected?
Some motorhomes can provide a warning if you delve into the settings menu.
andy63
4,672
15,017
south shields
None
since 1990
I think the d+ wire isn't a supply to the charger as the op suggested.. it is the wire that enables the distribution board to receive a d+ signal from the base vehicle.. and when you hook up and run the charger the d+ signal is disabled..
Thats if its like mine ..ie a dsc300 cbe board and a cbe mains charging unit..
Andy
Steve and Denise
Steve and Denise
5,287
14,081
Spalding LINCS
A Class Carthago
Since 2008
It would appear to be a 12v 50ma signal to the ds470 as others have said đź‘Ť maybe I could get a 50ma regulated supply to send to the DS 470 that would make it function as normal ?
Apr 27, 2016
6,872
7,991
Manchester
A class Hymer
Since the 80s
Does this signal from the charger to the DS470 actually do anything, apart from maybe showing an indicator that the mains is connected? On my EBL, it triggers a relay to trickle charge the starter battery from the mains, but maybe in the DS470 it doesn't do anything.
Steve and Denise
Steve and Denise
5,287
14,081
Spalding LINCS
A Class Carthago
Since 2008
I am not sure just yet but I have the option to put a feed to it with a small 50ma supply transformer from the charger main supply.
There is very little info available on the DS470 Cbe won’t tell you anything and Carthago dealers don’t want to know.
Apr 2, 2017
338
489
Maidstone, UK
Laika Kreos 5009
Since 2010
Is there an update on this subject as I’m just anout to fit a victron charger to my CBE system, Steve and Denise did you find that you lost the trickle charge to the chassis battery?
