Fitting A Split Charge Relay? (1 Viewer)
Oct 1, 2013
7,510
19,932
Lanzarote
Nil by mouth
Lots
I've decided to get one of these but folk seem to want lots of dosh to fit them.
Are they easy to fit? I know naff about leccy but do have common sense and can follow instructions.
Or best to pay a pro?
And could anybody recommend a suitable one from eBay please?
Cheers
Yorick
Oct 1, 2013
7,510
19,932
Lanzarote
Nil by mouth
Lots
And also the fridge is wired directly to the van battery at the mo as per the instructions in handbook.
would a split charger somehow be fitted so that the fridge won't draw a charge when the engine is not running?
17,611
43,139
it really is very simple to fit a split charge relay. even easier is to fit a smart relay as it needs less wires
one fused thick wire from the positive terminal of the van battery to the relay
one wire from the negative of the van battery to the relay
one thick wire from the relay to the leisure battery
one thick wire from the relay to the fridge
using a smart relay, it will detect the voltage at the van battery and switch on when the alternator is charging. otherwise you need to find an ignition triggered live circuit
probably about an hour or so work and parts about ÂŁ30 with smart relay
http://www.ebay.co.uk/itm/RYDER-Sup...arts_Vehicles_CarParts_SM&hash=item19dd6a6a33
Apr 9, 2013
663
373
Ayr
Which fridge? Which handbook? That sounds like bizarre advice guaranteed to flatten your battery should you forget to manually turn the 12 V supply to the fridge off.
Yorick
Oct 1, 2013
7,510
19,932
Lanzarote
Nil by mouth
Lots
It's a Dometic fridge and manual says so. That's why I wanna sort it all out.
Badknee
7,407
412,368
notloB
Vantage Neo
Living the dream.
And also the fridge is wired directly to the van battery at the mo as per the instructions in handbook?
Don't like the sound of that, starter battery or leisure battery?
Badknee
7,407
412,368
notloB
Vantage Neo
Living the dream.
No, no, no, it's bad enough flattening the leisure battery but a nightmare to flatten the starter battery ..................... push anyone?
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
It should say 'directly to the starter battery, via a relay'. Directly, as in - separate wiring, not shared with anything else. But it must go via a relay, so that it only runs while the engine is running. The relay senses the rise in voltage that occurs when the alternator starts charging, then makes the connection to the fridge.
This is a separate relay to the split charge relay which controls the charging of the leisure battery (at least, it should be). Having said that, combination units are available.
Simple split-charge systems are ok for leisure battery charging if you don't need to rely on the leisure battery for much or for very long. If you need more from your batteries, then add solar panels if you stay in one place for a while, or a battery-to-battery charger if you drive about quite frequently - or both, but now we are talking serious dosh.
I would get a pro to fit either relay. It's not that they are difficult, but if electrics is all a black art, then you are missing the knowledge to spot some minor issue that could cause quite a serious problem. A basic split-charge system won't take long to do unless the wiring runs are complicated.
Put the bike in the van, take a day or two off, make a trip out of it & go to the Severn Gorge Park site in Telford. Dave Newell is just over the road - Jackie will even make the campsite booking for you. You & Dave are both into motorsport, except he has two more wheels on his wagon. With the bike for transport, there is plenty to see in the area while he puts in whatever you need. Most importantly, he'll tell you what you really need, which might not be what you first thought.
P.S. All this assumes that the fridge is a three way absorption fridge - runs on gas, 12v or mains. Direct to the leisure battery would make sense if it's a compressor fridge.
2,288
9,926
Model number?
Dometic do an awful lot of fridges.
yes, but they all work with the same principal.. they all need TWO 12v supplies, one from each battery.
1. 12v A Permanent supply from the leisure battery to power the electronics. ( whether on LPG, Mains or 12vdc )
2. 12v supply from the engine battery that is only switched on when the engine is running . This is done via a relay ( so called split charge relay) operated by the voltage from the alternator when the engine starts.. The same relay (provided it has 2 sets of contacts) is also be used to charge the leisure battery.
eddie
8,146
41,212
Taunton Somerset
RV
since 1989
Right! two relays, one for the leisure battery and one for the fridge. You can use Voltage Sensing Relays (VSR) and they will automatically "close" (start to work) when the engine is started and the engine battery voltage reaches a certain voltage. When the engine is turned off the voltage will drop and this will cause the relay to open "stop working"
This means that no power will be taken from the engine battery from the fridge or the leisure battery.
The down side of VSR's is that they can play up if you have a solar panel connected to the engine battery as this can cause the VSR to "think" that the engine is running.
It could be better in such cases to connect the alternator to the relay conventionally. It takes longer, and will cost you more (if having it fitted) but will be more reliable in the long run
I PM'd you about your chassis
Eddie
Jun 30, 2010
7,924
27,229
1992 VW Auto sleeper Mono
Since 2005 this time
Yes! Many thanks Badknee, you have just solved one of my Problems with the master battery losing charge:clap2::notworthy2:
May your Camels have a thousand babies and may your enemies have a thousand Fleas!:notworthy2::notworthy2:
Jan 28, 2008
10,116
18,381
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
one method is to use a smartcom relay to switch the split charge relay the advantage is you get the correct supply for tyhe fridge
cable size is important as you dont want to be loosing current along the wires
Broken Link Removed not sure if you will be able to see this diagram if not pm me ill try another method
Yorick
Oct 1, 2013
7,510
19,932
Lanzarote
Nil by mouth
Lots
Eddie
Hmm, that's got me worried. I'm fitting a 150w panel and it makes sense that a split charge relay could be confused. But what problems could occur ?
Does anybody else have a solar panel and SCR fitted ?
Cheers
My mate is fitting it all and he is a whizz with electrics so just need to tell him what to do
eddie
8,146
41,212
Taunton Somerset
RV
since 1989
Yorick
Oct 1, 2013
7,510
19,932
Lanzarote
Nil by mouth
Lots
I have come across this and it seems too good to be true. Seems very simple
Is it as good as it sounds ?
Badknee
7,407
412,368
notloB
Vantage Neo
Living the dream.
That looks an easy fit Yorick.
Badknee
7,407
412,368
notloB
Vantage Neo
Living the dream.
That was wierd, there one minute gone the next then back again?
Jan 28, 2008
10,116
18,381
Renalt burstner
the smart coms are best used to switch a larger relayalthough rated at 30 amps they dont last long if used alone ive got more or less what you want ie split charge syten fridge relay and solar
i use the smartcom to swicth a larger relay but run the fridge of the smartcom
