First MOT Beware
May 29, 2020
10
23
Low Line Weinsberg
5 months
Hi all just had our first MOT on our Weinsberg Pepper and it FAILED.
Probably in many previous threads so sorry I had not read, I assumed would be OK
Our Weinsberg is on a Peugeot Boxer 2L 130 Blue with its terrible over protective and restrictive CAM bus system.
Failures.
1) The rear lights The Reversing light and the Fog warning lights are on the wrong side for the UK, needed re wiring and the lenses moving nearside to off side and visa versa. (most of the vans use will be in Europe so will we be stopped there for being the wrong way HA HA)
2) We had c hanged the head lamp and main beam bulbs for LED these were removed and changed back to halogen type as they said they could not align the beam to the correct spread. I had fitted type suggested by other motor home You Tube advice, when fitted I checked the beam pattern on black gates ant the alignment was good.
3) I had fitted LED bulbs in my rear indicators and although the rate of flashing on the outside of the vehicle was OK the flasher sound from the dashboard was fast (just as though a bulb had failed on a standard circuit) The reason for changing the rear was the original incandescent bulbs were not bright behind the lenses.
Although 2&3 above are my doing to improve the lighting all should be aware, if they have changed to LED lights the new MOT upgrade will detect them and fail the MOT.
Number 1 however was easily sorted on our van as the lenses were interchangeable and the lights rewired. On some European vans the lenses may be an integrated unit which will have to be changed to a UK standard.
Thankfully the cost of the retest was no charge but the repairs did cost.
So be prepared and do the changes before the test.
I have done many mods on this van and have worked in electrical engineering all my career, but the CAM system on this vehicle bemuses me and seems to restrict any modifications, enough said.
We do love the van and can't wait to get up and go for it.
Hope this information helps some. No criticism please after 47 years of working life politics we are retired now and want the quiet life we deserve.
LOL Des&Dek
Mar 23, 2012
5,475
16,227
sleights
c class
Unless it's an import that suggests that the manufacturers are fitting the reversing and fog lights incorrectly and they've been the wrong way around for at least 3 years!
Feb 16, 2013
14,927
26,910
uttoxeter
ambulance conversion
50 years
A reversing light isn't necessary for mot.
Lenny HB
29,428
50,899
On the coast in West Sussex
Hymer B678 Dynamic Line
There is no way it could have passed the import check so it has been registered illegally.
Jan 19, 2014
5,616
13,884
Derbyshire
Elddis Accordo 105
since 2014
Our van will need MOTing, it's not been done for 2 years in July 😳 first the six month extension applied and now it's sorn. It wont fail on any LED lighting though.
Because it hasn't got any! 😍
Jun 12, 2016
1,095
2,873
Scottish Borders
Globecar Revolution
Since 2006
Friends PVC had this issue with the fog light
It was easier to rewire than trail to Fiat to reset cambus
Big issue was getting access to get light clusters off converters had not allowed for access to get to the fixings
Van was a RHD UK spected vehicle
Mar 23, 2012
5,475
16,227
sleights
c class
Same with ours. I keep thinking about doing it but like most jobs haven't got around to it. Logically we don't often drive in it in the dark!
Badknee
5,861
183,988
notloB
Hobby 750 tag.
Full timing for five years and loving it!
We’re having news coming through for our classics that have had upgraded headlights, any change from the norm is being jumped on apparently.
Mar 16, 2021
300
563
Riddings, UK
GLOBECAR CAMPSCOUT
30 YEARS
Led's for our vans are a good idea, but you must get the right types, on canbus systems you would need the resistive type, they mimic a incandescent bulb from the canbus point of view.
led's for headlights seem a good idea, but i have never come across any that would give an acceptable beam pattern, as yet, as in the main head lights are designed for incandescent bulbs, not led, sadly.
Jul 15, 2020
1,295
7,272
Hartford Cheshire
Auto-Trail Imala 734
New to owning, years renting.
Our Imala is almost due for MOT. I am hoping it's all standard and sails through. Wont be messing with lights.
Lenny HB
29,428
50,899
I've put LED's in my headlamps and the beam pattern is better, they are hella projector lamps, I belive if upgrading to LED's projector lamps give much better results.
I will leave them in for the MOT as in the projector lamp you can't see the bulb and my MOT guy is pretty laid back.
bobandjanie
7,016
12,687
Javea, Spain
Pilote V600g
Ours has been for its first mot today in Spain its 4 years here then every 2 until its 10 years old, but this one a Pilote van fog and reversing lights both sides, as was our previous Rapido van.🤔 Bob.
Feb 21, 2016
3,780
11,426
Uk
C class
Since 2017
Great post,very interesting.
Not that any of it actually applies to me.................I’ve still got candles in my headlights,but I’ve done away with having a guy in front with a red flag. :ROFLMAO: :ROFLMAO::rofl::rofl:
Aug 18, 2014
16,505
69,426
Spain
Transit PVC
6 years since restarting
You don't need to see the bulb you can tell straight away by the whiteness of the light. You are lucky to be able to get away with it as here you've no chance at most itv stations.
mine came with led's in th reversing lights. Passed an itv 6 months after I bought it & when the tow bar was fitted. When I changed it to a camper van 6 months later it was due another & they spotted the led's . Had to take them out there & then & swop for normal bulbs.
Coolcats
2,374
3,212
HymerCar Ayres Rock
Which means the pre-delivery check was never carried out the OP should not have had to pay for this, the VW Camper we brought from a ‘professional’ conversion company failed to check the basics. As an example the fog lamp had never worked ( I noticed this in its 2nd year) and whilst the conversion had been sold via a VW dealer they had also failed to check the basics, turned out the fog lamp was switch off in software and a cable had a nick in it as well so they had two faults to fix the fog lamp. The original dealer had to pay our local dealer to fix the issue. I would suggest the OP goes back to the originating dealer and ask for them to contribute to the repairs
denisejoe
4,085
6,553
Warden isle of sheppy
Since 2004
I would have thought most vans for eu and gb would have twin wiring s should only have to change the lens over and one one wire in each used to have a caravan that had this
