As its Amazon "Prime" day and there is a cracking deal on the 4k Firestick....can anyone tell me if these will power and run ok from the Avtex USB port as i don't want to have a separate power supply..
The same happened to our set which was bought in 2016. It does not get enough power to operate (Insufficient power) even if you leave it for 5 minutes. As we have a usb hub in a cupboard above the TV it was easy enough to run a dedicated USB lead along with the TV cables. Interesting to see that some work and others don't. Going to have another look at the TV settings in case something needs turned on that I missed when I originally set up the 4k firestick.I connected up our new 4K Amazon Firestick to our Avtex 21" TV a couple of weeks ago, and it showed up on screen as "insufficient power" when I tried to power it from a USB port on the LH Side of the TV.
The HDMI ports are located on the underside of the TV so I connected the Firestick to the HDMI 1 Port, and the power lead was put into a USB port.
I assumed that I would need to plug it into a decent 12V source like a new USB C rated socket in the van, but I need to get a usb extension lead to do that.
I am surprised to read that others have been more successful than I have, was even thinking of buying the in line 12v booster box for £24 on Amazon, but it has mixed reviews.
I wonder why it works for some & not for others?, maybe its the age/model of Avtex TV, ours is 4 years old now.
Looking forward to hearing any suggestions.
LES
Hopefully just what Landy Andy says and if you can boost the power by an alternative source long enough to get the setup done, your Firestick will work as needed - despite low power warnings.The stick needs more power when being setup.
Bugger....wish I'd waited now. Just paid £39.99 for the latest HD version.Yes they will run from the Avtex usb
Edit
That is a cracking deal
Ordering now View attachment 508898
Unlucky.Bugger....wish I'd waited now. Just paid £39.99 for the latest HD version.
Just a picture. Words on the link: -That deal looks like just the Firestick and remote. No power lead of any sort?
Included in the Box
Fire TV Stick 4K, HDMI extender cable for Fire TV Stick 4K, Alexa Voice Remote (2nd Generation), 2 AAA batteries, USB cable and power adaptor, Quick Start Guide.
The Firestick comes with everything in the box, including the USB power lead, plus an HDMI short extension lead for the firestick itself which can be handy depending where your TV HDMI slots are placed, on our Avtex they are on the underside of the tele just to make it that bit more awkward to find.That deal looks like just the Firestick and remote. No power lead of any sort?
Indeed they can be awkward to use .The Firestick comes with everything in the box, including the USB power lead, plus an HDMI short extension lead for the firestick itself which can be handy depending where your TV HDMI slots are placed, on our Avtex they are on the underside of the tele just to make it that bit more awkward to find.
LES
Snap, It doesn't work on our Avtex tv either but works on our Falcon. To be fair our Avtex tv is a few years old.I connected up our new 4K Amazon Firestick to our Avtex 21" TV a couple of weeks ago, and it showed up on screen as "insufficient power" when I tried to power it from a USB port on the LH Side of the TV.
LES
Just added a FireStick to a new 12/240 volt TV and as per the above post had to set up via separate USB socket, then all ok after that to run off the 0.5A USB socket from the TV.The stick needs more power when being setup. So once that is done you will have more luck running it of TV usb, also when it gives you the warning about not enough power, you can just ignore the message and it continues to work.
It’s pretty good out of the box.Bought one on the deal. When it arrives its of to a man that can make it do magic I'm not so sure but been told I need one in my life. Not really one for TV got all I need on the www
We’ve just tried ours this evening as we’re away and like others got the low power thing, ignored it and carried on.Anyone found a way round Avtex not being on the Drop Down list?
Is what Prog reported in this post "can-amazon-firestick-remote-control-my-avtex-tv" still relevant? A similar name type thingAnyone found a way round Avtex not being on the Drop Down list?
No, It does come with all cables and adapter and batts. I bought the light as don't really need 4k in van and thought it might not need as much power.That deal looks like just the Firestick and remote. No power lead of any sort?
