Someone has been telling you porkies, Firestick is powered by 5v from a USB socket, often they will work OK from one of the USB sockets on the TV
Our Manta TV USB doesn't have enough oomph to power the Firestick so we have to use a separate USB socket. No biggy as it's in the TV cupboard
Are you using firestick offgrid via an invertor?Our Manta TV USB doesn't have enough oomph to power the Firestick so we have to use a separate USB socket. No biggy as it's in the TV cupboard anyway
They said they were plugging it into USB socket, there is no need for an inverter it's 5 volt.Are you using firestick offgrid via an invertor?
They may use an inverter to power the tv if not on hook up I suppose depends on power requirement of tvAre you using firestick offgrid via an invertor?
Sorry for lack of info. I have a 24" tv with usb for firestick works ok on ehu. If off grid I understand that I need an inverter I'm just trying to establish what size inverter to buy ( just for tv / firestick use) and do I need any thing else apart from wifi of course.It is possible that the OP doesn't have usb sockets. Looking elsewhere I see they have a 2002 Burnster Harmony 625. Were there USB sockets in 2002? Is there a usb socket on the TV?
An alternative would be a converter from a 12V socket to USB.
Not enough detail from the OP on why they need an inverter.
I had a cheap 150 w inverter which was ok for the tv and sky boxSorry for lack of info. I have a 24" tv with usb for firestick works ok on ehu. If off grid I understand that I need an inverter I'm just trying to establish what size inverter to buy ( just for tv / firestick use) and do I need any thing else apart from wifi of course.
Yes just for the tv and firestick. Tv is not 12vSo the inverter is for the TV? Is not a 12V TV aswell? Most motorhomes/caravans have multi voltage TV's?
In that case you will need an inverter for the TV but depending on your TV it may be worth investing in a 12v TV.Yes just for the tv and firestick. Tv is not 12v
Interesting…..we have a Manta tv (24”) and a 4K Firestick (faster processor) and it works just fine from the tv usb……Our Manta TV USB doesn't have enough oomph to power the Firestick so we have to use a separate USB socket. No biggy as it's in the TV cupboard anyway
I like the sound of those……do they bring a smile to your face as well….?!?Now all runs of the pleasure batteries
Oh yes. that’s why I have them! The pleasure of leisure off grid. No typo there. Do need to replace the old lead acids though.I like the sound of those……do they bring a smile to your face as well….?!?
Can you post a photo of the label on the back of your TV so we can advise.
