Filling the fresh water tank
Masters
Elddiss Encore 255
Elddiss Encore 255 currently on site have filled the fresh water tank but the gray water is tank is also filling and I am unable to empty it. Any clues as to what I am doing wrong ?
Are you using gauges to tell what's full and what isn't.
It's simply not possible to fill the grey tank any other way than via sink/shower waste plugholes.....there's no other pipework to the grey tank.
If you are going by gauges then ignore it and get it fixed
Unless you have the hose in the waste outlet pipe this shouldnt happen. The fresh and wate tanks are seperate
Reactions: f6c
Just as a check, open your grey waste outlet into a bucket ,empty it and refill your fresh water up whilst the grey tap is open.
I do wish people would return and explain what happened after posting a question.
I don't disagree, but it's only been a day and a half. Perhaps he's a bit embarrassed?
As a new member of this forum I did not realise that it was the custom to post a reply. I have been able to sort out the problem, thank you for your help
What was the cure?
Hi Masters, not a custom but helpful for the likes of me who may have a similar problem, find it in the search and then know what to do. By joining the forum you have inadvertently become part of the brains trust and a solution provider. there are also reactions to choose from on the bottom rhs of posts. The forum can be a great problem solving database when the solution is added.
Enjoy your time on the forum and your MH adventures
Cush
Coming back to a thread and updating on problems Funsters have had and how it was solved is a good way of helping those that may have the same problem in the future plus it's interesting to hear how others resolve or not their problem.
There is a massive wealth of knowledge on this forum and adding your experiences can only help to add to this knowledge base.
I for one have been aided in having problems solved from forum members' experiences and as such, I can help others by passing on my route to solving problems.
