Filling Gaslow / Alugas bottles. (1 Viewer)
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi, yes you can. you fit a t piece into the filling hose .ideally with two valves open one to the calor .when its got enough shut that one and open the one to your gaslow . easy .infact the garager pump will switch off at about 90% .even if you dont have the valves .i,m assuming the filler point as a none return valve in it .
GJH
29,450
38,827
None, now sold
2006 to 2022
hi, yes you can. [HI]you fit a t piece into the filling hose .ideally with two valves open one to the calor [/HI].when its got enough shut that one and open the one to your gaslow . easy .infact the garager pump will switch off at about 90% .even if you dont have the valves .i,m assuming the filler point as a none return valve in it .
But that assumes that user refilling of Calor bottles isn't an accident waiting to happen :Smile: That subject has been aired on numerous occasions and I'm certainly not convinced that the risks are acceptable :Smile:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
yet many fit bottles with unreliable 80%cut out and fill with confidance that it will work.
i was only answering a question offered by the op. if you just fill a part full gaslow and it fails puts you just as likely to over fill. if its empty at least you might think thats alot and stop.
as it is i,m not happy that gaslow or any of the others are any safer.
i do know that when i fill my tank with the bleed off valve cracked open that when liquid comes out its 80%full. just like the huge tank here that calor fill.
43,302
49,289
Forecourt and Non-Forecourt PoI sets,
beware of the above.......many places listed only sell bottled gas but are still on the POI set because they still sell gas.
best to ring ahead to check if they actually sell Autogas, as opposed to calor.
there are a few listed locally on various POI sets but only two listed sell Autogas...the rest bottles only
Craig Rogers
646
412
Midlands, UK (Welsh!)
Newbie!
Imagine my (almost) embarrasment last night.
Pulled into the Uttoxeter Services on the A50 to fill the Gaslow up last night.
The gauge on the bottle has never worked, so no idea how much was left in there.
We have done a few weekends away and also our 10 day trip down to Lake Garda. These involved many hot water heats, cooking, a little fridge use (when not in EHU) and some extended BBQ (including cooking baked potatoes).
So as we are off-EHU this weekend, I didn't want to run out of gas as the fridge will be on it all weekend.
Original fillup was around 22litres (11Kg cylinder) so I assumed that this must be getting a bit low.
Pulled up to the pump, attached the nozzle, clipped it on, pressed the button and about 10 seconds later, CLICK!
Imagine my suprise when I look up and it's taken just over 6 litres, yes, all of £4 to top up. :Eeek:
Went into pay and realised I didn't have any cash, just my Debit Card...... Couple of bottles of water later and I get my bill up to £6.
Heyupluv
3,862
1,593
France,
touring many years..42+
I wished my set up would use the same...like our last M/H......4 weeks away in Brittany just come back, only EHU three nights out of the 4 weeks.....we only use the gas on heating (alde) for a hour in the morning which also heats the water and of course the fridge....the cooking.....and 2 hours at night on the ALDE wet heating........4 weeks later, 3 X refills of 11kg (around 60 to 66ltr) LPG alum gas bottles refillables:Eeek::Doh::cry:....as somebody said to me life's bitch sometimes :ROFLMAO::ROFLMAO::Doh: Now give me time to think this one out:Doh: life's a bitch Mmmmm I will ask SWMBO what he ment
Craig Rogers
646
412
Newbie!
I'm guessing it's the heating that takes the gas? Our heating is Diesel, so we save a bit on that.
We also don't go off-EHU that often so the fridge isn't on constant gas.
Heyupluv
3,862
1,593
France,
Yes Craig you are guessing correct....that is exactly what we think...it is the only difference from our last Motorhome....as it is the same size fridge & freezer....more or less the same size cooker.... both had / have ovens......but this has the ALDE WET central heating takes 30 mins to get the radiators hot..but then it comes into its own the whole van is warm/hot , the second floor with the pipes underneath them are warm ...the garage is warm/hot...this motorhome is a little bit longer about 1/2 a meter than the last van so may have a little more to heat
NO hot or cold spots....
The other was the truma blow heating.. which is blowing hot air very quickly..that is the only difference:Doh:
Mel
SPUD'N'T
190
4,318
YORK ENGLAND
COACHBUILT (LOW PROFILE)
since 2008
You are quite close to me so I suggest you get an account with Countrywide Farmers.
See my response to another LPG thread earlier today:
Broken Link Removed
do any funsters know of a similar thing in the north yorkshire area ?. I have tried various google searches all to no avail !
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
try a google for flogas .they can be cheaper on gas. i,m lucky we have one at the end of our road.
Craig Rogers
646
412
Newbie!
If you have one close, then fair enough, but it's so cheap and fill ups are not so frequent that a special journey to get it cheaper is a bit of a false economy.
Jnet
10
4
Moray
Autosleeper symbol
I'm a newbie
Is your insurance cover affected if you fit a gasit system yourself? And do you need it signed off by a registered gas fitter . Thanks for advice
