Happy1 Normally 6mm on fig 8 but can be either 6mm or 4mm on wind out awnings, my connector has both sizes of chord (6 mm one side and both 6mm and 4mm the other) can dig it out and take photo for you if it helps)
Messed about with these for a few years but some are selling cheaper ones where the awning slides off. So i had someone sew the 4mm section onto the 6mm . Much better.
Thanks for all the responses 6mm it is!!
Bought a bargain omnistor safari room from eBay and its 50cm too short on the front panel so making an extension in clear plastic like the window stuff and attaching to exiting front same as you join the side to the front. Hope it works or my bargain will be less of a bargain!
