is anybody into fibre glass repairs can you mix body colour in with the fibre glass so it dosent have to be painted or is that not possible anybody know
yes it is grp and gel coat the fibre glass ive seen before is red or am i missing something
Sorry I don't agree Mo, a good boat grp repair man will do a superb job of matching the Gel coat.Not to my knowledge satisfactorily..
You would be better off doing a good fibre glass job yourself and let a body shop blow it over..
They would come up with a nye on identical match..
Or you could try rattle cans of primer and top coat.... but doubt it would be a perfect match..
I agree with mo if it was a fibre glass repairSorry I don't agree Mo, a good boat grp repair man will do a superb job of matching the Gel coat.
All correct but I will add that you can mix a bit of MW solution with your final Gel coat to prevent it staying tacky.gell coat is normally put in the mould first, ( it is mixed with a pigment to give the colour) the mat and resin is then layered up after woulds to give the strength. The gell is set by chemical reaction and remains sticky when open to the air. Garage roofs are done in reverse, the final coat is flowcoat this does not leave it sticky. Again flowcoat can have pigment addded. On gell coat repairs I use tin foil to get the gell coat to set without air. Does depend on what you are trying to repair.
