Lenny HB
- Oct 18, 2007
- 53,304
- 149,474
- Hymer B678 DL
In Spain at the moment and the van through a bit of a wobbly today.
A bit of background first, a few ago months at 14000 miles ago I swapped the spare onto RHS front, the other side had about 4mm tread depth. On a few a occasions I have had the LHS front wheel tramping and the traction control cutting in. I had put it down to the more worn tyre on that side. So before this trip as the LHS front had done 19000 now I swapped one of the rears to the front which had a bit more tread. With this arrangement it did it again just the once a few days ago.
Now today's problem I had just pulled out of a parking area started up a hill the van virtually stops, both front wheels tramping engine running traction control comes on, front wheels burning rubber. Engine almost stalls a few times, we are stationary burning rubber it appears like the traction control is putting the brakes on and the engine is fighting it. No sign of clutch slipping but loverly smell of burning rubber and big black marks on the road.
I reversed back down to a fairly flat bit, tried again the same problem on the flat. Turned ignition off restarted and all was fine.
Half a mile later come to a steep hill starts off fine part the way up van slows down but revs try to stay up, it the changes to 2nd and is all OK. A bit weird as Comformatic is only a robotised manual and there was no sign of a slipping clutch. I'm thinking the brakes may have been coming on.
Next we come to a really big hill so I flipped it into manual and had no problems at all getting up it.
These hills were in quick succession as we were going around a mountainous wildlife park.
My thoughts are it could be an ABS sensor or ABS ECU problem.
Just hoping someone has had similar problems and give me some guidance.
