Rivermount
- Dec 3, 2019
- 53
- 82
- Van Conversion
- Since 2019, a bit before lockdown!
I have found that the handbrake light is not comming on when operated on my 2019 fiat 250.
As it stopped working after the dealers had the drivers seat out to deal with another problem, I thought it may be a simple wire off on the handbrake switch but it is attached. What doesn't look correct is the switch itself. It looks a bit as though the switch is not all there! I have also put a meter across the terminal to earth (only one wire goes to the switch ) and it is not connecting at all. I'm sure the switch is broken and some of it is missing, including the contacts that break when the handbrake is operated.
My question is, should the switch look like this?
P.s. the handbrake light works on the dashboard when ignition is on but not after starting so the lamp is ok.
