SandraL
- Jan 24, 2012
- 1,373
- 985
- Hymer b694sl
- Since 2012 + Caravanner for 20+ years
Today pumped front tyres up from 50 to 70 psi as was not using van until january. Did both tyres and then tried on back tyre. On starting pump connected to back tyre 15a fuse blew. Changed fuse and pump ran but sounded very rough.
On taking pump apart the nylon gearwheel had some teeth melted. Assume piston seized but motor turned, motor has metal gearwheel which stripped the nylon gearwheel.
I suggest leaving pump to cool down after each tyre, perhaps a cup of tea?
Also the gunge cansister has date stamp useby 02/16, this on a van first registered 06/13.
Assume they are available.
Think I might try a bicycle track pump, no fuses, no long leads required but some excercise........
