fiat ducato oil cooler (1 Viewer)
Feb 20, 2010
465
827
winchcombe
swift sundance 630g
Hi all i have a small water leak on the oil cooler on my fiat ducato 2004 anyone done this ? Is it the whole unit or a seal ? cheers matt
Dec 6, 2011
11,011
23,174
South Wales
Coach built Adria
please correct me if i am wrong but i thought they were air cooled , no water involved...
matt34
Feb 20, 2010
465
827
winchcombe
swift sundance 630g
Next to the oil filter or across from it is a black object thought it was or is the oil cooler there is a small drip of water from it, i thought it was the oil cooler but im no machanic so forgive me.
11,011
23,174
South Wales
Coach built Adria
you may be correct as i am not fully familiar with your model but i think the cooler looks like this,
but there are a few types. and... i believe one type does have water flow so i could be misleading you...
sorry if i am
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
I have no knowledge of your van but lots of oil cooler's (heat exchanger) are water cooled, Not one of my favorite ways of cooling oil, good in cold conditions for warming it up though.
Aug 18, 2014
22,592
121,527
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Is it the one that is trapped(sandwiched) between the oil body & the oil filter & with 2 hoses attached to it ? If so yes it is a one piece unit & has a seal on the engine side as the seal on other side is provided by the filter. Nothing in it to leak unless it becomes perforated. The usual fault, that I had, was one of the 2 water pipes gets eaten away & becomes difficult to get a decent clamping with the jubilee clip. I just silver soldered alonger piece of pipe into the original.
matt34
Feb 20, 2010
465
827
winchcombe
swift sundance 630g
sorry if i am
Yes that's it or similar,i took it out for a spin as had been laid up for 2 months, then i noticed water under the engine bay did a bit of investigating and found it to be leaking,hopefully an o'ring then its due for a mot so will get them to look at it,Ive been googling it for days and not a thing of how to repair one and you found it straight away.(y)
matt34
Feb 20, 2010
465
827
winchcombe
swift sundance 630g
C
The yellow arrow is the cooler and the green is where the oil filter goes,i havent taken the pic its off the net.
Aug 18, 2014
22,592
121,527
Lorca,Murcia,Spain
Transit PVC
That's a newer type to mine which is fitted where your green arrow for the filter is & then filter fits after.
Feb 22, 2011
9,127
17,797
Newcastle under Lyme
Hymer B544 A Class
Since 2015
@matt34
It might be worth asking on the fiat forum.
There are some knowledgeable guys to offer advice, although you might have your answer from Gus
