Paul and Pippa
Hello ,could anyone advise on the mileage for a Fiat Ducato 130 multijet oil and filter change please ,Kind regards, Paul
I took our van into a Fiat Professional garage yesterday ( for recall work) Ours is a 2.3 Euro 6. The garage recommended an oil service yearly and full service, including brake fluid change, every 2 years.Hello ,could anyone advise on the mileage for a Fiat Ducato 130 multijet oil and filter change please ,Kind regards, Paul
How do you tell when the brake fluid is contaminated?I couldn’t stand the thought of 28000 miles on the same oil in a petrol engine never mind a diesel, though I could cope with the two years.
Ours has been serviced from new by Fiat Professional and it has fresh oil and filter annually, our choice, though the brake fluid still hasn’t been changed and next month will be it’s five year service. It only needs changing if it contaminated.
They test it with a very expensive machine that measures its boiling point, if it’s contaminated with water it gets changed. Changing it every two years is pointless if it’s not contaminated. Modern fluids are much improved to what they used to be.How do you tell when the brake fluid is contaminated?
It's a ripoff it does not need a Full service unless you are doing as the Fiat schedules advise, you could spend a fortune on something that's not necessary I would 'Bounce' it off another Dealer before you let your garage touch your motorhome, a oil and filter change is not a bad idea , in my Fiat book it says if you do low mileages change the engine oil and filter annually, mines on a 17 plate .I took our van into a Fiat Professional garage yesterday ( for recall work) Ours is a 2.3 Euro 6. The garage recommended an oil service yearly and full service, including brake fluid change, every 2 years.
I wouldn’t be comfortable leaving the oil for 28000 miles!
I’ll be getting the oil service done on its first anniversary.
I have always changed oil and filter every 12 months or sooner depending on mileage. The only vehicle we have had where I didn’t do this was a new Beetle. We let it run the 24000 miles before it’s first service ( 18 months) and it was fine. But, it was on a personal lease so if it broke, we would not have to pay.It's a ripoff it does not need a Full service unless you are doing as the Fiat schedules advise, you could spend a fortune on something that's not necessary I would 'Bounce' it off another Dealer before you let your garage touch your motorhome, a oil and filter change is not a bad idea , in my Fiat book it says if you do low mileages change the engine oil and filter annually, mines on a 17 plate .
The Main thing is to make sure before you go to the Fiat Main Dealer is that they put the correct oil ,I had an up and downer with my garage, I said it should have Sae 0 - 30 they said no, sae 5-30
Fiat Customer Services and Petronas when I phoned them said I was correct, if yours is on a 17 or 18 plate I would look at your handbook.
ps. there are letters after the Sae 0-30 but I don't have my handbook in front of me .
Tony A
I’ll go by the garage recommendation and get my brake fluid changed at each 2 year interval, contaminated or not, as my yearly mileage is quite high.They test it with a very expensive machine that measures its boiling point, if it’s contaminated with water it gets changed. Changing it every two years is pointless if it’s not contaminated. Modern fluids are much improved to what they used to be.
I mentioned a change at two years and they (Fiat Professional) told me the above.
I would not and do not ‘skimp on their maintenance’
Think l will do the same,,, thank youI took our van into a Fiat Professional garage yesterday ( for recall work) Ours is a 2.3 Euro 6. The garage recommended an oil service yearly and full service, including brake fluid change, every 2 years.
No it won't.If we change the oil and filter ourselves (between services) will it bring a service light on that will require resetting.
I read something that you have to take it to a Fiat dealer or a garage with suitable software to turn the light off costing approximately £40...check online forumIf we change the oil and filter ourselves (between services) will it bring a service light on that will require resetting.
Unfortunately Fully Synthetic oil used in mine is around a £100 per oil change.Had my Hymer oil service done today. Always done every year regardless of miles. Why pay eye watering amounts of your hard earned £££ on a Motorhome and skimp on £30 worth of oil.
I change both every 3000 milesHello ,could anyone advise on the mileage for a Fiat Ducato 130 multijet oil and filter change please ,Kind regards, Paul
Yes oil change is a tricky one , but there again we changed engine oil at 1000 miles in the 1960's !!I don't believe some of the comments here, Just how much did you pay for your pride and joy?
Tens of thousands of your hard earned pounds and people scrimp on the cost of a few litres of oil and a filter, in all of my years of motoring and in the many vehicles I have owned I have always changed my oil and filter every 5000 miles.
Never had to change any injectors why because the engine oil has always been at the top of it's protection, am I going over the top with my oil changes well consider the cost for a set of injectors or the older heater plugs and pit that against the cost of the oil and filter and you will be quids in.
I couldn't care less what it says in the service manual I will keep on changing my oil and filter every 5000 miles.
Just had mine done today 1year old oil used was Morris 0W/30 Euro6 oil £70.79 for 6.5 ltrs filter £14.78 all + VAT?Unfortunately Fully Synthetic oil used in mine is around a £100 per oil change.
